air pump pressure
Old Jan 17, 2004 | 12:45 AM
cdrad51's Avatar
Lorem ipsum dolor sit ame
air pump pressure
I noticed yesterday that the hose going from the air pump to the pipe going to the main cat broke. I was going to replace it, but before that decided to test the pump itself. So i blocked the hose with my finger while the engine was running my and didn't notice any pressure. Does that mean the pump is not working or would I normally not be able to feel pressure by doing that?
Old Jan 17, 2004 | 07:35 AM
Steve Shulz's Avatar
The higher the rpm the more pressure. It is designed to flood the cat with air (solution to polution is dilution) When you smog test your doing it at a load so typically it wont come on until after 1100 or so. It does have a good bit o pressure not sure how much to be exact though. Is your car kinda loud air sounding when you get on it? With that pipe broke you should me makiing hella noise from air and exhaust through that pipe.
Old Jan 17, 2004 | 09:41 AM
cdrad51's Avatar
Oh good point, I'll try to feel the pressure while revving up and see. Noisy? you bet, but it was already, as the system has a leak somewhere in the cats, which has being going on since way earlier than when the hose broke. I haven't fixed the leak as that's probably what keeps the car running since the cats must be clogged as hell. I bought a Bonez converter system to remedy, I'm just waiting to get a new mid pipe and muffler to replace the whole thing. By then I want to make sure the air pump is operating properly to avoid premature failure of the main cat.
Old Jan 17, 2004 | 09:58 PM
cdrad51's Avatar
hmm did the same with the engine at 1500, felt nothing...
Old Jan 18, 2004 | 07:55 AM
Do you have any air coming off the side of the ACV (the 3/4" hose going up to the carb on the drivers side) If you do then your ACV (like mine) is shot. Ive heard there is a rubber flapper that breaks and will cause this. There is also a procedure in the Haynes manual to adjust the timing of this device too, but it basically says if you can feel air coming out of (pic in the book) then replace the ACV.
Old Jan 19, 2004 | 11:51 AM
cdrad51's Avatar
I can test that, but would a faulty ACV valve cause the split air pipe to receive no air?
Old Jan 19, 2004 | 03:00 PM
specRX7_22's Avatar
to see if your pump is actually working at all.... remove the top of the air cleaner and put your thumb over the larger of the 2 holes (i think its the larger one) at the bottom of the air box. You should feel a significant amount of suction.
Old Jan 19, 2004 | 03:18 PM
cdrad51's Avatar
Even at idle or do I need to rev it up?
Old Jan 19, 2004 | 04:34 PM
specRX7_22's Avatar
At idle.... you should not need to rev it at all.
Old Jan 20, 2004 | 12:10 AM
cdrad51's Avatar
OK so I tried that and there is suction alright, so the pump is working. Now I need to figure out why air is not coming out of the hose going to the main cat.
Old Jan 20, 2004 | 04:03 PM
specRX7_22's Avatar
The ACV distributes air to 3 places....
1. from idle to 3000rpms, air is injected into the exhaust
ports
2. 3000+rpms air is vented into the air cleaner
3. at some other times it can be injected into the cat, it
looks like when the choke it on
Old Jan 20, 2004 | 04:24 PM
specRX7_22's Avatar
so i'm pretty sure that its OK that your not feeling anything at the cat.
Old Jan 20, 2004 | 05:51 PM
cdrad51's Avatar
I'm confused. I thought the air pump was supposed to supply a constant flow of air to the cats to aid combustion of toxic chemicals, and without it, there will be unburned fuel residuals that will eventually clog the cats.
Old Jan 20, 2004 | 08:24 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
There is a check valve in the line that goes from the manifold to the converter. If this check valve gets plugged, no air can get to the converters.
Alternately, if the ACV goes bad, that could cause the same problem. Just a couple of possibilities.
Old Jan 20, 2004 | 10:37 PM
cdrad51's Avatar
I was checking the hose that goes from the manifold to the check valve, so that wouldn't be it. So it must be the ACV, unless I'm missing something. I hate the emissions system, it gives me a headache!
Old Jan 21, 2004 | 01:14 AM
Wankelguy's Avatar
Then open the garage door.
(sorry, I HAD to do it...)
Old Jan 21, 2004 | 02:49 AM
cdrad51's Avatar
no kidding. I was working in the engine bay with the engine running, and with a current exhaust leak, my eyes were watering within seconds!
Old Jan 21, 2004 | 06:34 PM
cdrad51's Avatar
any advice/tips from the pros/gurus/experts?
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
