Input on GT 66 turbo...I did a search first...
Old Jan 13, 2004 | 10:38 PM
fastrx7man's Avatar
Looking for 10's
I am looking for input from people who have or know about this turbo. See my sig for current mods. I will take care of the fuel upgrade and of course Mohammad at MZM (www.mzmperformance.com) will have it tuned perfectly.
What kind of power can I expect? How will it be as a daily driver? (Not that I use the car as a daily driver...but if I did?)
Here is the write up on the turbo...Garret GT 66 ball bearing sinlge turbo with less than 4K miles on it. Compressor housing its a .55 and the exhuast housing is a .84 comes with HKS race gate waste gate, HKS 3inch downpipe with factory O2 sensor, SS braided line for the oil inlet line, HKS air intake filter, the turbo manifold, and maybe somthing else i forgot to mention.
Thanks for your input...and of course I will not install a single turbo until I run a 11.5et on the stock twins
Old Jan 13, 2004 | 10:58 PM
rx7tt95's Avatar
Photo Diety
You may want to try the single turbo section....my answer would be that if it's truly a Garrett GT66, it's WAAAAY too big. Period. Won't work. Won't fit under the hood. No kidding. Think GT40.
Old Jan 13, 2004 | 11:11 PM
fastrx7man's Avatar
Looking for 10's
It may get moved to the single section but for now I am hoping for some input here. The turbo is currently installed on an FD...So it should fit.
Old Jan 13, 2004 | 11:26 PM
rx7tt95's Avatar
Photo Diety
Are you sure it's a GT66 and not a T66...big difference.
Old Jan 13, 2004 | 11:40 PM
Scrub's Avatar
bow leggin'
I think he is talking about a T66. It probally wouldn't be a great daily driver if you were to use it as one.
Old Jan 14, 2004 | 12:37 AM
artguy's Avatar
WTB** Very Low Miles 94-95
and why do you want this turbo?
what kind of driving situations do you see yourself in?
is this a street car?
that is how you choose...not because its huge or because its cheap.
j
Old Jan 14, 2004 | 06:36 AM
fastrx7man's Avatar
Looking for 10's
j
The car is mainly used at the drag strip. I drive it a couple times per month to work.
I am looking to eventually get down into the high 10s at the strip....
Old Jan 15, 2004 | 10:27 PM
fastrx7man's Avatar
Looking for 10's
Anyone else????
Old Jan 15, 2004 | 10:48 PM
boostin13b's Avatar
I had a turbonetics T66 with a 50 something AR(I can't remember the actual spec) on my TII with a large street port and it was great. I dynoed at 412 to the wheel with 18 psi. I never got to bump it up above that because I was hit head on by a stupid high school girl with no insurence. But I hit full boost at about 4600 RPM which isn't bad for a ported TII motor. It should drop with a ported 13REW because of the larger ports but even 4600 isn't bad. A lot of the supra's I build people are going with the T88's and they don't spool until 5500. The T66 is one of my most favorites, but if your looking for something that will get you to the 400's easily with a less lag, go with the 60-1 series turbo, that's what I currently run on a few of my custumers cars and will be on my own soon cause I road race a lot. Just my 2 cents.
Old Jan 16, 2004 | 01:51 AM
chuck8313BTSDS's Avatar
fastrx7man
Get the biggest turbo you can....haha
How's things? Happy to see you going single.
Are you going to port the motor later? How much boost are you going to push. No porting get a T66 with a .96 p-trim. Maybe a .84 a/r with a q-trim. If you go with a .84 q-trim, you can alway upgrade the exhaust side when you do port the motor. Just a thought. good luck.. Remember my set? T66. 2720lbs with me, 128mph equals 440-450wrhp at 20psi. S4 turboII motor. Your motor should push more hp at the same boost.
chuck
Old Jan 16, 2004 | 04:28 AM
Sl0w7's Avatar
i think you mean trim... a .50 AR on a 7 would spool at idle... lol
-Keith
Old Jan 16, 2004 | 08:16 AM
$150FC's Avatar
Currently Winning
he probably means a .50 A/R on the compressor side.
turn the car off and you hear the blowoff valve open haha "wa-chhhh"
a GT66 would be waay too big. A ball-bearing T66 would not, however. Which is the turbo in question?
Old Jan 16, 2004 | 02:54 PM
sub-zero's Avatar
Go for the T-66. I dont drive My car much and ran a T-72 with a .96 hotside. It is a bit much for the street and You need a ton of fuel to get any where close to the "sweet spot". I am going with the T-66 now and think it will be perfect for a few strip runs a year and a couple of drives per week. If You have the fuel to run @ 22-24 PSI with a T-66, I think it will kick ***.
https://www.rx7club.com/forum/showth...hreadid=259877
Nice deal...
Old Jan 16, 2004 | 10:23 PM
Sl0w7's Avatar
hahahhaha nice...
Old Jan 16, 2004 | 11:00 PM
Innovative makes an upgraded version of the t-66 which they call a gt-66, that may be what it is.
http://www.innovativeturbo.com/cgi-b...rbo/index.html
Old Jan 16, 2004 | 11:10 PM
Here's its map....
Vartok
16
Oct 8, 2015 04:49 PM
Einheri
Oct 7, 2015 12:23 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
Postman09
Sep 29, 2015 11:23 AM
Jingkun
Sep 28, 2015 01:53 PM
