Oil survey
Old Oct 15, 2001 | 08:03 AM
neomaximus's Avatar
Oil survey
Hey.......what oil are you guys using in 3rd gens....i'm just curious what the consesus is out there
Old Oct 15, 2001 | 08:20 AM
Mahjik's Avatar
Mr. Links
Lightbulb
It's starting to get cooler around here so I'm running 10w-30 right now.
From what I gather from most people, warmer weather use 20w-50, colder weather use 10w-30. Avoid 10w-40 because of the additives.
Also, some people run synthetic and like it a lot even though Mazda recommends not to. Racing Beat (http://www.racingbeat.com) noted some very good benifits of using synthetic oils. The only downside they found was the "break in" period was a little be longer than with mineral oils. Their suggestion is to use mineral oils on the break in period of a rotary engine, then after that use synthetic oils.
Old Oct 15, 2001 | 09:25 AM
95R2-89TII Ground Zero's Avatar
Banned
I used to use 0W-30 Mobil 1 synthetic, but I swtiched to 30 SAE, Castrol......I was told not to use sythetics cause they don't fully combust....oil injection.
Old Oct 15, 2001 | 09:36 AM
Mahjik's Avatar
Mr. Links
Actually, here is some info straight from the Racing Beat Rotary Performance Technical Manual:
"The Mazda factory does not recommend the use of synthetic oils in their rotary engines - specifically addressing this issue in the Owner's Manual.
In 1979, Racing Beat began testing synthetic lubrication products. Without a doubt, the best synthetic oils do perform well in extreme heat (over 300 F) and extreme cold (below 32 F), but by the nature of Mazda's rotary engine, the oil temperature never exceeds 250 F without severe engine damage due to other factors. In Souther California, we have difficulty seeing the low-temperature benefits: however, when we put synthetic lubricants in the engine, transmission, and differential in our IMSA GTU race car, we immediately saw what we later found to be a common result: The oil temperature in all three locations dropped 5 to 10 F for the same operating conditions. This is apparently due to two factors: reduced friction between sliding surfaces, and reduced foaming. As we continued to use synthetic oil products it became clear that they genuinely reduced wear. We also found benefits in street use. On two occassions, cars with "scratchy" transmissions synchronizers were completely cured by a change to synthetic gear lube. After many years of experience with these products we have observed only one problem: because of the reduced friction, the time necessary to break in an engine, transmission, or limted slip differential (standard differentials are no problem) is excessively long, so we recommend using mineral oil in all three for a time to ensure rapid break in."
Racing Beat has been racing and building rotary engines since the RX2 so I would imagine they know a little something about them.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
