17/18 stagger or all 18s for FD??
Old Jan 6, 2004 | 02:00 PM
xchaos's Avatar
I'm at a crossroads here.
Originally, was going to go 9x17 and 9.5x18. Already have the 18s with 275/35s on them and they fit great.
Should I stay with the 9x17s 43mm offset and 255/40s?? Or will the 9.5x18s 45mm offset and 255/35s fit better?
My only concern here is rubbing in the front. The 18s look to be about .25" closer to the fender than the 17s. I do have the option of 8.5x18s with 45mm...but would like the wider 9.5 if it will fit.
Opinions? I'm about to order the 2 front wheels/tires and just can't decide!
Old Jan 7, 2004 | 11:12 AM
xchaos's Avatar
I've decided to go with the 8.5x18s in the front with +38 offset. That will give me almost .25" more room up front than the 9.5x18s and I can still put the 255/35s on there. The rim is a little narrow for 255s, but should be fine with a little protection as well.
The wheels are 5zigen FN01R-Cs at about $240 each.
rx7jocke
72
Jun 17, 2016 03:48 AM
