bosch part numbers
Old Jan 6, 2004 | 10:24 AM
hondah8er's Avatar
mazdaspeed 3 coming soon
Question bosch part numbers
Does anyone know the part number for bosch 1200cc injectors? I'm not sure if its a motorsport item or not but I can't seem to find the part number for them. Or even find them anywhere except for www.dysonrotary.com.au. I'm convinced I can get them for less then 190AUS seeing as there 1600's are quite a bit cheaper.
If it matters, I need a pair for a 87 turbo 2
This list of fuel injectors from bosch's australia website might help...
http://www.bosch.com.au/sat/motorspo...linjectors.pdf
Old Jan 7, 2004 | 12:20 AM
sunami's Avatar
i dont have the web addy handy, but search for marren fuel injection. they sell all sizes of bosch injectors at good prices.
Old Jan 7, 2004 | 08:52 AM
hondah8er's Avatar
Thanks. I know of Marren but I want 1200's. The closest they sell is 1008cc.
Old Jan 7, 2004 | 01:28 PM
hondah8er's Avatar
come on...nobody knows
Old Jan 7, 2004 | 03:26 PM
setzep's Avatar
why don't you want 1600?
Old Jan 8, 2004 | 08:58 AM
hondah8er's Avatar
Looks like I will probably end up with 1600's. One I wanted to be different and 1200 secondaries is more then enough fuel for 12-13 psi. I will never be turning the boost up to 20 psi or anything like that. I wanted to run 720x1200's which is plenty of fuel for my hp goals. Not to mention the primary to secondary crossover isn't that large.
Plus the fact that i'm having a hard time finding them when I know they exist makes me want to find them even more if that makes any sense.
Old Jan 8, 2004 | 09:09 AM
hondah8er's Avatar
Found it....thanks guys.
Old Jan 8, 2004 | 09:49 AM
hondah8er's Avatar
If you go to http://www.bosch.com.au/sat/motorspo.../products.htm? and look under fuel injectors you will find the 1200cc injector part number 0 280 150 842. There is also an application note beside it and if you look above where the injectors are listed it says "for CNG operation only" What does that mean?
I have confirmation from a bosch rep in australia that this is the injector i've been looking for. 4.6 ohms of resistance and flow rate 1207cc/minute.
diabolical1
30
Jan 30, 2016 05:50 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
