Secondary Fuel Injector Install
Old Jan 3, 2004 | 05:50 PM
UltraJuaN's Avatar
I am tryin to install the RX7.com (Rotary Performance) fuel rail kit with 1600's and ran into a problem. Do you have to remove the stock injector grommets for them to fit and seal properly or do you keep them in there? It seems that the injectors won't seal properly without the grommets. I did remove the diffusers already. Any help would greatly be appreciaated.
P.S. I did a search for this and could not find the answer.
Old Jan 3, 2004 | 06:44 PM
shawnk's Avatar
Perpetual Rebuilder
I used a sliver of 5/8" hose for the seal.
I did a write up for keith's rails a while back that may help.
http://www.3rdgenrx7.com/keithshowto.htm
Shawn
82streetracer
Aug 23, 2015 09:28 AM
