Dealing with Pull Type Clutch Video
Old Dec 31, 2003 | 10:56 AM
Wargasm's Avatar
Weird Cat Man
Hello I was bored today so I made a video showing how the pull type clutch in an FD works since many people find themselves either unable to remove it or unable to install it.
Enjoy!
http://video.google.com/videoplay?do...58290919&hl=en
Brian
Old Dec 31, 2003 | 11:35 AM
Mahjik's Avatar
Mr. Links
Good stuff!
Send the link to Hi Rev Tuners! j/k'ing
Wish I had seen something like that before the first time I ever separated the tranny.
Old Dec 31, 2003 | 02:16 PM
patriick's Avatar
FD enthusiast
Great job! Keep 'em coming!
Old Jun 10, 2004 | 12:25 PM
RotorMotorRX7's Avatar
Sweet Job on the Video
Old Jun 14, 2004 | 04:19 AM
RotorMotor's Avatar
DRIVE THE ROTARY SPORTS
NICE! thanks, that video helped tons!
Old Jun 20, 2004 | 06:53 AM
jspecracer7's Avatar
1JZ powered
lmfao...Damn Brian you were bored! GJ!
Old Jun 20, 2004 | 12:31 PM
pp13bnos's Avatar
Pineapple Racer
Thanks alot. This could not have come at a better time. Yesterday I whent to the strip in my single turbo 3rd gen. The clutch is/was stock with around 50k miles on it. Needless to say, the clutch hooked up all the way through 3rd gear, (I was spining the tires through 3rd. ) but did'nt even make an effort to hook up in 4th gear. I allready have a clutch to put in my car, but still need a pressure plate/throw out bearing.
I have'nt searched yet, but I was wondering if you would like to give a breif discription on how to remove the transmition. I've completed dozens of push style clutch swaps, but never a pull type. Normaly I search before asking questions, but I feel a rough outline of a transmition removal would be great with your video.
Thanks once again for taking the time. CJ
Old Jun 26, 2004 | 09:49 PM
1JZ powered
Pulling the tranny's pretty straight forward.
Remove the shifter from inside the car.
Drain the tranny fluid.
Unbolt the PPF(total of 5 x 21mm bolts).
Unbolt the drive shaft(4 x 14mm boltsor 12mm...I forgot) and remove from output shaft.
Disconnect tranny harness (I believe there are 4 connectors).
Unbolt the starter from the tranny (2 x 14mm bolts) and then the tranny from the engine (4 x 14mm bolts).
That should just about cover it but if I missed anything feel free to chime in. After that, do Brian's method to removing the clutch from the flywheel and pull the tranny out.
Old Jun 27, 2004 | 05:41 PM
pp13bnos's Avatar
Pineapple Racer
Thanks. CJ
Old Jul 13, 2004 | 02:15 PM
2a+RoN's Avatar
Thanks so much, I'm downloading it right now. I just came home from where I'm doing the work on my car to figure that out and this find really made my day.
Old Aug 28, 2004 | 01:17 PM
Cryptic's Avatar
dwankeled
you missed the clutch line that is above the starter.
-Clutch release cyclinder (2 bolts)
-and 1 bolt were it secures the clutch line to the tranny
It snagged me when the tranny was dropping down, kinda sucked
Old Nov 10, 2004 | 09:39 PM
Stix37867's Avatar
Got Rotors?
Great video. Helped greatly. Thanks
Old Nov 11, 2004 | 04:24 AM
jeremyb's Avatar
Hi....
im getting some "error codec" when the windows media player opens it. I can hear him talking and everything... just no video
Old Nov 13, 2004 | 01:05 PM
Dan Stevenson's Avatar
Great video!
I had to remove my stock downpipe both times I changed my clutch. Is there a way to do it without removing it?
My clutch disc that I purchased from Racing Beat broke into four pieces and wedge itself into the pressure plate (stock car, 5K miles on disc, and no drag racing). I had to remove the pressure plates bolts though the window in the transmission to get the trans to finally seprate from the engine. It was a long day.
Old Dec 2, 2004 | 12:33 AM
jeremyb's Avatar
Hi....
anyone have a solution?
Old Dec 2, 2004 | 12:10 PM
Shinobi-X's Avatar
Sensory Experience
Brian, next time you're bored, let me know if you'd like to tune my engine in exchange for a drink or two.
Old Dec 19, 2004 | 08:15 AM
badddrx7's Avatar
All Spooled Up
Use Real Player to view it. It works. You may need a component for your windows media.
Tom
Old Dec 27, 2004 | 03:29 PM
VagaBond-X's Avatar
Hmmmm
Tom
you need the right codec to play the file... 10 % left and i'll play it and tell u which codec to download....
EDIT: it uses the divx codec (widely used codec) you can get it at www.divx.com
Old Dec 29, 2004 | 05:30 PM
00RB's Avatar
very timely
Th0m4s
Feb 26, 2019 02:04 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
rxmiles
Aug 24, 2015 02:07 PM
