driveshaft
Old Oct 11, 2001 | 07:32 PM
JIMMY54's Avatar
GSL-SE PRO
driveshaft
does a 12a have the same driveshaft has a 13b?
Old Oct 11, 2001 | 09:50 PM
Montrealer's Avatar
It depends on the years, I know for a fact that the GSL-SE's driveshaft does not fit on a 81 but after 83 I belive its the same thing.
Old Oct 11, 2001 | 11:46 PM
smnc's Avatar
EliteHardcoreCannuckSquad
I thought the GSL-SE's have a bigger driveshaft? I'm not sure tho.
Old Oct 12, 2001 | 01:03 AM
peejay's Avatar
Old [Sch|F]ool
An -SE driveshaft should be the same as a '83-85 12A driveshaft. Same length, same transmission splines, same pinion flange.
'79-82 driveshafts have different pinion flanges from the '83-85 models. The driveshafts are all the same as far as length and the trans yoke are concerned (not counting auto cars), and the pinion flanges are interchangeable too, so you can put a late shaft in an early car by changing the pinion flange (preferably by installing a complete rearend ). Or vice-versa, if you like that sort of thing.
- PJ (Yeah, let's put a '79 rear axle in a GSL-SE...)
Old Oct 12, 2001 | 03:13 AM
Felix Wankel's Avatar
Super Newbie
LOL You know some dumbass somewhere has done that already
Old Oct 12, 2001 | 01:43 PM
smnc's Avatar
There ya go, I just learned somthing new about the Non -SE's.
Old Oct 12, 2001 | 02:00 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
You looking for a driveshaft? Me too. If you find someone with a parts car (or a couple of driveshafts) let me know. I want a spare
Old Oct 12, 2001 | 05:28 PM
JIMMY54's Avatar
GSL-SE PRO
I am going to purchase an 84' parts car hopefully, and i belive it is a 12a.. I need a new driveshaft and i was hoping to be able to use it off that car.
Old Oct 12, 2001 | 11:15 PM
GSL-SE's Avatar
Are they aluminum or steel. And if they are steel how muxh would an aluminum one cost
Old Oct 13, 2001 | 09:09 AM
JIMMY54's Avatar
GSL-SE PRO
they are steel.
series1rx7
Sep 27, 2015 05:46 PM
