Power FC Power FC boost control kit question
Old Dec 8, 2003 | 07:09 PM
Is it possible that I'm getting min boost from the PFC with the boost control kit installed incorrectly... would I get min boost or no boost in that case. By min boost I mean 3 or so pounds of boost. I installed the POWER FC boost control kit solenoid as if it was an AVC-R solenoid. Is that correct or did I install it the wrong way?
Here's what I did:
I installed it exactly like the picture on page 48 (according to the manual)
or page 52 of 61
(if you are looking on the bottom) of the following link:
www.apexi-usa.com/productdocumentation/
electronics_savcr_ins.pdf
It is the page titled "FD3S Specific hosing diagram"... and then "AVC-R connection diagram"...
Please let me know if that is right or I should have installed it differently?!?
Thanks a bunch...
Mike
Old Dec 8, 2003 | 08:51 PM
Tim Benton's Avatar
FD title holder since 94
why not disconnect it, but leave it in the car, just not hooked up and see what your boost level is.
Tim
Old Dec 9, 2003 | 07:16 PM
Thanks for the response... I'll give it a shot and let you know! What do you think about the set up though? did I set it up wrong?
Old Dec 12, 2003 | 11:28 PM
I think the the Power FC is sending a signal to the boost controller because when I switch between sequential and non-sequential on the commander there is definately a difference... Perhaps it isn't sending enough of a signal... or I need to alter how the boost controller is set up... Do I need to replumb the hoses? If so... how should I do it?
cristoDathird
28
May 30, 2019 08:47 PM
