tach works, buzzer doesn't......
Old Dec 5, 2003 | 04:54 PM
4meuwil's Avatar
it worked last week....now nothing. Any ideas?
Old Dec 5, 2003 | 05:08 PM
hornbm's Avatar
FD > FB > FC
why do you want it to? I hate my buzzer.
Old Dec 5, 2003 | 06:35 PM
erick1120's Avatar
I removed the damn thing from mine right after I got it. For some reason mine wouldn't shut off. If I had the fuse in that runs the dome light and the radio the buzzer would constantly go off.
Old Dec 5, 2003 | 09:50 PM
specRX7_22's Avatar
I would be willing to bet that half the cars on here has a non functional buzzer.
Old Dec 5, 2003 | 09:51 PM
mazdaverx713b's Avatar
Have RX-7, will restore
if you do a search on interior lights, you will find info on this
Old Dec 5, 2003 | 10:12 PM
faye x7's Avatar
brilliantly stupid
My 82 GSL, when I bought it about a year ago, the buzzer never worked. Either that or the previous ownder disconnected it as he disconnected quite a few things and changed things around in the car.
Howevery, my bro's 84 GSL, his buzzer works...and it's kinda funny the first few times, but it's annoying after then.
Old Dec 5, 2003 | 11:25 PM
bizarro's Avatar
when i first heard mine i thought a civic was honking its horn at me
Old Dec 5, 2003 | 11:37 PM
Cody's Avatar
SKELETOR!
BE GLAD it doesn't work. Its annoying. I hit mine every shift. It gets quite old after awhile.
Old Dec 6, 2003 | 09:17 AM
brianw's Avatar
I didn't even know I had one! I'm glad it doesn't work. Where are they set?
Old Dec 6, 2003 | 09:30 AM
bizarro's Avatar
mine hits at around 6k
Old Dec 6, 2003 | 09:31 AM
mar3's Avatar
Administrator
Doesn't matter! You don't want it to work!
Old Dec 6, 2003 | 10:50 AM
onepointone's Avatar
i say what i want
wow, mine hits aroudn 7200. i was trying to rig a light to go off instead of the buzzer, but i cant figure out how the buzzer gets power.
Old Dec 6, 2003 | 03:38 PM
Heh, mine has been broken since i had the car....
Old Dec 6, 2003 | 10:29 PM
hornbm's Avatar
FD > FB > FC
The buzzer is supposed to go off at 7,000RPM.... redline. My dad said he disconnected his when he had his rx-2. I'm gonna ask him how he did it so I can get rid of mine as well.
Old Dec 6, 2003 | 11:36 PM
4meuwil's Avatar
finding a way to make the stock buzzer run a shift light instead of nuzzing would be awesome. All we'd have to do is find the wire that triggers it, the type of output it sends (pos or neg) and build a relay to use that input to trigger the shift light....
Old Dec 6, 2003 | 11:48 PM
jsinrx7's Avatar
Ahhh a shift light! I am there! that is on the list of thing to do!! hell yeah! should be easy, when you take out the cluster, it is mounted right on the back. I cant remember if there is seperate wires running it or if it is soldered onto the panel, but either way it should be simple if you know how to solder
Old Dec 7, 2003 | 01:02 AM
i say what i want
well i have a red LED mounted in my cluster between the tach and speedo, but its not hooked up to anything. i thought it would be a no-brainer where the buzzer got its power from, but i couldnt fine where to put it. it would be cool to take the buzzer out and just have the light. i was also going to use a (forgot the name) so i could have a **** that could adjust when the light came on. any ideas?
streetlegal?
Mar 17, 2022 02:46 PM
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
thecody59
40
Aug 23, 2015 06:41 PM
smikels
Aug 18, 2015 01:26 PM
