17inch wheels, what about the gears and speedo?
Old Oct 8, 2001 | 01:15 PM
CYAL8R's Avatar
hey guys im getting me some 17inch rims and tires real soon, but i need to know what else i am going to have to do to accomodate these...i know i'll need an adapter to bolt them on, and someone told me that they would totally affect the gear timing and the speedometer! help!
Old Oct 8, 2001 | 03:48 PM
Scott 89t2's Avatar
SOLD THE RX-7!
if you get correct size wheels you shouldn't need anything to put them on. also the speedo will be the same as long as you get the same diameter tires. wheels don't effect that.
Old Oct 8, 2001 | 03:54 PM
Flobb's Avatar
Rattle can retard
I don't know about the gear timing but as for the speedo, here is a tire size comparison thing to help you.
Tire Size Calc
But to save you time. If your stock tires are 205/60/15 like mine then a 215/45/17 will about do it. Otherwise you have to go like 245/40/17 to get closer. But that takes one fat wheel.
Old Oct 18, 2001 | 03:19 AM
Node's Avatar
http://www.miata.net/garage/tirecalc.html
LMFAO
put it to 335 80 23
damn tractor tire calculator ;-)
Old Oct 19, 2001 | 03:29 PM
sublimeracing's Avatar
discount tire co and tire rack both have websites that will answer your question but its pretty simple... if you don't wanna mess up the speedo and stuff just remember that for every inch you increase the rim size you need to subtract one from the tire profile. ie:bigger rim=low profile tires.
Old Oct 19, 2001 | 11:33 PM
the_glass_man's Avatar
Will u do me a kindness?
Yeah, you can call them to and most of the people have a lot of good info and can help you out with your decision.
Old Oct 20, 2001 | 06:38 AM
RX-7 GT's Avatar
HyperREV.com
do you like to repeat what other people say
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
OrangeMax
Sep 4, 2015 10:42 AM
Coolant_Leak
Aug 30, 2015 11:18 AM
