K2RD FD3S Fuel Damper Eliminator
Old Nov 26, 2003 | 08:09 PM
K2RD's Avatar
Newbie
http://www.k2rd.com/products/fuel/1743100.html
Gets rid of stock fuel rail damper on 13BREW primary rail. Costs a lot less than the stock replacement fuel damper.
-K2RD
Old Nov 27, 2003 | 11:04 AM
I know it's been discussed before, but what is the drawback(s) of removing the FPD?
Old Nov 27, 2003 | 02:24 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
With the primary and secondary fuel rail running one after another, the fuel changes as one set of injectors fire causing a ripple in the full pressure at the other fuel injectors. Not haveing the same fuel pressure means your not injecting the same amount of fuel. Im not sure if its _bad_, from what i understand it would just stop you from making the same amount of power.
Under a high boost where every tiny bit of fuel counts, could see it bing a problem though
-Jacob
Old Nov 27, 2003 | 08:34 PM
Evil Aviator's Avatar
Rotorhead
The fuel injectors take a beating. However, most people who would use something like that PD eliminator are going to use a good fuel pressure regulator, such as SX, with a built-in pulsation damper.
Old Nov 30, 2003 | 09:39 PM
Piranha's Avatar
what 7
-Jacob
It wouldn't be a ripple on the next injectors, pressure in liquid is equal on the whole system. There isn't anything to smooth out injector pulses. A lot of people run banjo bolts on FCs instead of our dampers. I haven't seen anything bad happen, yet.
Ever have a sink where you can shut off the water REALLY fast and then hear the pipes bang? That is the same thing, without a damper.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Snoopy FD
Dec 8, 2015 01:45 PM
Snook
21
Sep 1, 2015 06:32 PM
