Microtech finally passed emissions
Old Nov 26, 2003 | 02:44 PM
Silver88GXL's Avatar
Ugggg!! Well, I finally passed emissions. Not enough time in the day and week to get work, school, and tune the ole Rx7 for emissions.
Anyhow, she blew the best numbers she has ever had.
25mph test
97 HC 174 allowed,
.62 CO% 1.12 allowed,
67 NOx 1258 allowed
15mph test
66 HC 180 allowed
.02% CO% 1.01 allowed
356 NOx 1378 allowed
Save the map and wait till next year. Thanks for all the input that you all had for me.
Old Nov 26, 2003 | 03:33 PM
10sec rx7's Avatar
damm man pissed it in!
did you use any alky??
Dale
Old Nov 26, 2003 | 05:09 PM
There was some in there, but it wan't as much as before. I had about a gallon of isoprople to about 4 gallons of gas the two times previous, but this time I just left what I had in there previous with a couple gallons of gas added.
But it is nice to be done with dealing with that. The map should take care of me for a while until I can get an EGT and wideband to really set things.
Old Nov 26, 2003 | 06:35 PM
10sec rx7's Avatar
thats pretty damm good man!!
good work!
Old Nov 27, 2003 | 11:01 PM
TonyTurboII's Avatar
Glock Lover
So what did it take to pass? Did you have an airpump hooked up?
Old Nov 30, 2003 | 12:05 PM
RotaryRevn's Avatar
yeah I was wondering if you could tell us what emissions equipment you were running? Did you have the egr valve, air pump, acv valve on there? Were you running all three cats?
thanks
John
Old Dec 3, 2003 | 08:40 PM
The emissions equipment was very simplistic. Electric airpump controlled by the microtech, pumping air directly into the Catco Highflow cat. No ACV, No EGR.
Just leaned the car out and heated the cat up really hot.
Old Dec 3, 2003 | 08:49 PM
RotaryRevn's Avatar
Wow, sweet! Thanks for the info! So basically just the airpump and cat, cool, I need to pull my last smog check and see how the limits differ for CA.
Old Dec 4, 2003 | 04:37 PM
Make sure to use the stock air injection pipe. It has that nifty one way check valve on it.
Old Dec 5, 2003 | 12:55 AM
RotaryRevn's Avatar
ok, thanks!
crackerjack
Canadian Forum
Oct 27, 2015 05:35 PM
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
