hard to restart after turned off.
Old Nov 17, 2003 | 12:45 PM
MicahMan's Avatar
That's Nice!!!!
Question hard to restart after turned off.
i have an 83 gsl and when i drive for a while and it is warmed up it has a hard time restarting. like it has too much fuel or it wants to hesitate. also i have a fuel pressure regulator on it, out of 6 it is set on 3. would this have anything to do with it. after it starts it runs great. it just hesitates to restart. when the engine is cold it starts right away. im confused. please help....
Old Nov 17, 2003 | 12:52 PM
coldy13's Avatar
Yeah, shutup kid.
Mine used to be impossible to start after I shut it off when it was warm. My solution was to put in a fuel cut switch. That way you can turn the fuel pump off before you shut off the car, which will keep it from flooding and being hard to start the next time.
MosesX605's Avatar
My wife bought me 2 RX-7s
Hard start after being warmed up can be a symptom of low compression. Might be a good idea to get it checked out.
Old Nov 17, 2003 | 03:28 PM
dude, you need to know EXACTLY what the fuel pressure to your car is. Setting 3? WTF is that? Get a gauge and find out precisely what you are pumping to the motor before doing anything else.
Old Nov 17, 2003 | 05:38 PM
FB II's Avatar
i bet your secondaries leak when you shut it off. yeeeep.
Old Nov 18, 2003 | 12:15 AM
Jeff20B's Avatar
Lapping = Fapping
I'd say fuel pressure too. I used to think hard warm starts were caused by missing chrome, but I changed the fuel pump and exhaust system, and it now starts really fast when fully warmed up.
Check for low compression too.
Old Nov 18, 2003 | 11:07 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
If it's flooding after you shut it off, the needle and seats are probably leaking. The float levels could be too high also.
The Shaolin
Sep 14, 2015 07:50 PM
CaptainKRM
15
Aug 29, 2015 01:33 PM
RPOdesign
Aug 27, 2015 11:42 PM
PhillyFC
Aug 21, 2015 06:36 PM
