My car wont go over 120:( what is wrong
Old Oct 4, 2001 | 10:37 PM
ejmack1's Avatar
Lawn Ornament
I was racing a VR4 today, 6:30 this morning, kicked his ***(my x-girlfirend just happened to be in his car) up until about 120, then my car wouldn't go anymore, i believe i have a bad rear turbo, or somethin is wrong with the control system, when i tee into the nipple right behind the CRV i get 2 psi, but on my bost gauge after 4500 RPM's i get about 7 psi? COuld this loss of boost cause such a decrease in top end....?
Thanks
Old Oct 4, 2001 | 11:00 PM
ZoomZoom's Avatar
SEMI-PRO
Well I dont know your mods but I would guess you either 1. have a boost leak 2. hitting fuel cut because of boost creep with a stock ecu and the cold weather and maybe you have a couple mods that would make this the cause as well. 3. your turbo control system is hosed up. 4. bad secondary turbo. 5. partially blocked Cat converter.
Old Oct 4, 2001 | 11:17 PM
ejmack1's Avatar
Lawn Ornament
Mods:
DP, MP, PULLEY's.....
Boost controller that doesn't seem to do anything, and yes i have it hooked up correctly, only seeing 7 psi on secondary....... 11psi on primary
Old Oct 4, 2001 | 11:35 PM
kwikrx7's Avatar
time to go non-sequential
highspeedrider
Sep 8, 2015 07:55 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
