LED tach
Old Nov 13, 2003 | 10:04 PM
LED tach
HOw would you hook your tach up to a set of LED lights that would light up as your revs rose? like they have on lemans cars?
Old Nov 13, 2003 | 10:18 PM
Gregs's Avatar
it would be hard to do, but possible witht he right knowledge and skill
i wouldnt mind it in the stock location
-greg
Old Nov 13, 2003 | 10:26 PM
i was thinking about putting it over the dash...in a place easy to see....i want it to light up green...then yellow then red....i have been thinking of repalcing my analog gadges with digital ones...
Old Nov 13, 2003 | 10:41 PM
honegod's Avatar
simple, put a series of contacts along the arc the tach needle sweeps, one contact per LED you want, run a wire along the needle, position the needle wire so it touches the contacts as it sweeps past.
you might want to do a little wizardry to keep the lights the needle has passed lit until the needle drops past them again.
since there wouldn't need to be lots of current, very fine wires could be used.
Old Nov 13, 2003 | 10:47 PM
thats what i was thinking...or use the motor that drives the tach (i think it is and electric tach right) to do something simmilar...but would it be durable? i was thinking about having the first contact wired to light the first light...the second contact lights the first 2 lights...ect...but all of the lights would go out when the contact was lost....so complicated
Old Nov 13, 2003 | 10:53 PM
Chemical's Avatar
Dont know if this will be of any use to you but I bookmarked it a long time ago..
http://members.***.net/marklein/tach/
Old Nov 13, 2003 | 10:55 PM
Chemical's Avatar
Another:
http://www.niksula.cs.hut.fi/~mdobru...cho/tacho.html
Old Nov 13, 2003 | 10:56 PM
that is exactly what i wanted....thanks alot....im on my way.
pfsantos
Sep 30, 2015 01:29 PM
Thor 18
Sep 28, 2015 07:35 PM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
subeone
Sep 24, 2015 09:58 PM
