Flooding in mid-range temp
Old Nov 12, 2003 | 05:32 PM
j-spec_wannabe's Avatar
Rotary []D[][\/][]D
Question Flooding in mid-range temp
I finally got my car going good except when I leave it sit for like 1-2 hours. I go to start it and it is terribly flooded and i can barely get it to start, its just flooded to hell, but when i leave it sit all night it fires right away when its totally cold, and starts when it is at working temp. Any thoughts?
Old Nov 12, 2003 | 07:13 PM
Rx7carl's Avatar
Airflow is my life
what car? S GS GSL GSL-SE ?
Old Nov 12, 2003 | 07:19 PM
matthewpims's Avatar
Ive got an 84 gsl se and mine has been doing the exact same damn thing, tho mine doesnt start at all, so if anyone gives you any ideas or you figure out whats goin on id be wonderfully delighted to know lol
Old Nov 12, 2003 | 08:46 PM
Rotary []D[][\/][]D
1980 SA22C, i dont know what model
Old Nov 13, 2003 | 08:22 AM
Rx7carl's Avatar
Airflow is my life
Sounds like your carb may be heating up after sitting, causing the fuel to boil over into the barrels. Do you still have your heat sheild? Check your float levels in the windows and make sure they arent too high. It should be right in the middle on level ground.
Old Nov 13, 2003 | 08:23 AM
Rx7carl's Avatar
Airflow is my life
SE's are notorious for this problem. Search for the answer, I know its here. Sorry I couldnt be more help.
Old Nov 13, 2003 | 12:43 PM
Rotary []D[][\/][]D
Ok i'll check it out and let you guys know
musker
Oct 1, 2015 05:58 PM
