Sponsored by: CARiD
Dirty Spark Plugs
Old Nov 3, 2003 | 05:00 PM
wyco's Avatar
Dirty Spark Plugs
Looking for help,
I have a T2 serries five rx7 and are having problems with carbon buildup on my sparkplugs, So much so that it was causing a misfire.
I am running Mazda Factory oil, and NGK 9's & 7's, I run the car almost exclusivly on high octane (98) wich is the best fuel available in New Zealand. The engine is a new rebuild (about 3 thousand km ago). I have had a factory Diagnosis done on the engine and there are no apparant engine error codes.
any help would be appreciated.
Old Nov 4, 2003 | 09:40 AM
Wargasm's Avatar
Weird Cat Man
does your car use up a lot of oil? Are the plug wires in good shape and securely fastened?
Brian
Old Nov 4, 2003 | 04:03 PM
wwilliam54's Avatar
it WILL run
you need to redline it more
Old Nov 5, 2003 | 03:40 AM
wyco's Avatar
Brian
No, car uses onlywhat you'd expect, plug leads visually seem fine and come up ok when tested with a multimeter, the only vague suggestion that has been give to me is that maybe the mixture is too rich but i dont know what to do about it.
Old Nov 11, 2003 | 08:19 PM
NGK series 7 and 9 plugs are cooler for highway driving meaning they run cooler than hotter series 6 and 8. That doesn't mean too much unless, as in your case, one sees a lot of carbon buildup on the plugs. Changing to the series 6/8 will make the plugs run hotter and burn off the carbon.
Refer to: http://www.mazdatrix.com/ign-2.htm
Old Nov 16, 2003 | 04:23 PM
wyco's Avatar
But surely something is causing the carbon to form, my understanding is that 7's & 9's are the factory spec plugs, so by running hotter plugs aren't I just masking an underlying problem?
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
