Power FC base mod maps with only intake and DP ok?
Old Oct 30, 2003 | 04:25 PM
SanJoRX7's Avatar
uid 0
Subject says it all. I don't have a catback yet, and probably won't for some time, and haven't yet installed the intake or hard pipes, but want to see what the story is with my PFC before I do.
I'm worried about running with the intake (will be m2 style box type) and pipes with my DP...I cannot afford a new engine right now, so I need to be safe about how I put these mods in.
Any helpful input is appreciated.
TIA,
Old Oct 30, 2003 | 05:35 PM
rynberg's Avatar
You should be plenty safe with the base map. Just run 10 psi. If you are really nervous about it and don't have time to check it on a wideband, just add 3% of fuel to cells above 4000 rpm and at 10+ psi of boost. See how it changes your knock values. I doubt you'll have to do anything though.
I'm running intake, SMIC, downpipe, and cat-back on the base map. At 10 psi, my knock doesn't go above 40. If I run 13 psi, the knock gets close to 100 on cold nights. I likely need to add a bit of fuel/retard timing at the higher boost cells.
BTW, be careful looking at the knock readings, you have to look at the steady WOT readings and not just the peak after a run.
Old Nov 1, 2003 | 01:24 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
I'm running dp,mp,cb,intake,IC and 10 psi of boost on the base map and it is fine as well. Shoots big flames when I let off the gas at high rpm.
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
20B Forum
Aug 19, 2015 01:47 PM
