Reverse light
Old Sep 30, 2001 | 02:46 AM
t_mak@mail.plymouth.edu's Avatar
Reverse light
Hey guys, I am trying to wire a switch that will allow me to turn the reverse light on even when i am driving. I got a question about the wiring. If I remember right, the reverse light sensor is in the tranny, with 2 wires coming out of it. One postitive and one negative. I am wondering how the light lights up. Does the switch create a ground that will allow the light to light up. If I do tap a switch into it. Do I tap one side of my switch to the positive wire and the other of the switch to the negative wire
Old Sep 30, 2001 | 02:53 AM
RX-7 GT's Avatar
HyperREV.com
one question...why do you want to do that for? hehe
Old Sep 30, 2001 | 04:09 AM
Node's Avatar
wouldnt you just need top provide power to the positive assuming its all powered by the same thing (battery)
if its 12v it shouldnt be a problem id think. Wire the positive to a positive where you are rigging it, and a negative to the positive of the light
im not sure about this. So wait for someone to confirm or deny my theory on going about this
Old Sep 30, 2001 | 03:24 PM
the easiest way is if you have a rear defroster. just pull out the wire on one side of the defroster, and add a wire to that. then run the wire down to the taillights and use a tap-in connector to splice into your reverse light power wire. then when you want to turn it on, just hit the rear defroster switch.
Old Sep 30, 2001 | 04:45 PM
CanadianRX7's Avatar
my back up lights dont even work
the bulbs r good its sumpthing else
Old Oct 1, 2001 | 01:05 AM
Icemark's Avatar
pretty common to have the switch contacts get dirty... either replace the switch or add a relay and have the factory switch drive the relay (and then the relay drive the back up lights).
Old Oct 1, 2001 | 07:43 AM
tesla042's Avatar
On the transmission, there is a plug that commonly comes loose that signals for the reverse lights to come on.. I think it's the problem with mine, i just haven't had a chance to look/fix it yet.
-Tesla
Old Oct 1, 2001 | 08:26 AM
I had that problem when I bought my car, tighten the switch. Reverse light works
Old Oct 1, 2001 | 02:11 PM
Node's Avatar
lol tmak you gonna put in strobes for your reverse lights? I know you are. Just confess
Old Oct 1, 2001 | 04:42 PM
haha nothing wrong with strobes!!!!!!!
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
