Power FC fuel cut?!?!?!
Old Oct 18, 2003 | 03:17 PM
93blackrx's Avatar
Unhappy fuel cut?!?!?!
right when I hit 15 psi the car just cuts out and jerks back as if there is fuel cut. I don't know what the fuel pressure is at the time that this happens but I looked at the injector duty cycles and they seem to be showing fuel cut.... where can I change this setting?
Matt
Old Oct 18, 2003 | 09:34 PM
rynberg's Avatar
Two questions:
1. What is your boost setting on the PFC? The PFC enacts fuel-cut if you exceed the boost setting by 0.25 kg/cm^2 (3.5 psi).
2. How can you tell you're hitting fuel-cut from your injector duty? You don't change your injector duty, you change the fuel maps. The injector duty simply reflects how hard the injectors are working.
EDIT: Just reread your sig -- you are running 850/1300 injectors with the stock twins at 15 psi? Your duty cycles should be very low, probably under 65%.
Old Oct 18, 2003 | 10:15 PM
93blackrx's Avatar
okay....just a little new at this pfc thing. the boost setting is .80 bar on the power fc, I think I'll raise it to 1.15 that should take care of the problem. I'm still running base maps, I need to get this bitch tuned.
Thanks for slaping me into shape berg...
Matt
Old Oct 19, 2003 | 02:45 PM
93blackrx's Avatar
wow..... That freakin worked, boost spiked to 20 psi. these turbos actualy have turbonectics modified compressor wheels and a different turbin wheel.. or so bryan told me when he rebuilt them. I just need to make a proper boost controller. I'm using a home depot style garden hose fitting right now, I just ordered stuff from mc master today.
Thanks for the help!!
alphawolff
Nov 17, 2015 05:57 PM
Snook
21
Sep 1, 2015 06:32 PM
armans
Aug 15, 2015 09:08 PM
