Going to the store... what should I get?
Old Sep 28, 2001 | 02:03 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
ANother question for the rotary experianced.. I'm planning to head over to RP this evening and I'm contemplating getting the Bonez Racing pipe (straght pipe w/ presilencer) cat replacement. I already have a Bonez Cat installed at the time, and this is a complete bolt in switch, so I can put the cat back in for the yearly poke in the tailpipe..
My question is, is there really much gain in a straight pipe over a high(er) flow cat? Is it worth my 135$?
Old Sep 30, 2001 | 05:24 PM
rx7gslse's Avatar
Bueler...... Bueler...
Anyone? Anyone.....
Old Sep 30, 2001 | 07:45 PM
Pittdp's Avatar
Sounds like a good idea to me, I would like to get one.
Old Oct 1, 2001 | 12:01 PM
P.O.S. Racing's Avatar
What did you end up getting at RP?
How’d you do on Sunday? The POS was plowing like a John Deere, I really need to replace my front springs, ball joints, tie rods, and rebuild my Idler Arm., Then get it aligned!
Old Oct 1, 2001 | 01:00 PM
rx7gslse's Avatar
I did pretty good on Sunday I think... I decreased my time on each run, 62, 61,60, and finally 59.3xxx... I was impressed. I couldn't for the life of me get that that last right handed hairpin correct. I either plowed into it or fishtailed around it or had way to much speed into it or something...
AS far as what I got at RP, nothing... I really wanted to get the cone filter intake they sell, and I need a muffler gasket, but they were out of stock on the intakes, and I sure as hell wasn't going to drive allo the way out there just for a 5$ part, so I'll probably go some other time when they've got stuff in stock. I really determined that I need help on the suspension. Offbrand performance tires and that worn out front suspension really don't help my racing much... I'm still trying to save up $ to get the whole GC setup that I want. My plan is to run the last few races this year w/ the same setup and change a bunch over the winter and run faster (albeit in CSP) next year..
shadowghost21
Aug 11, 2011 10:50 PM
TMadlem84
11
Jan 20, 2006 07:33 PM
