85 GSL-SE rear diff. probs.
Old Oct 6, 2003 | 12:45 AM
I own an 85 GSL-SE,I blew the motor about 2 years ago after only owning it for a month..Before I blew the motor,I remember the tires easily spun,as in only one tire really spun and it was night and day compared to the diff. on my 83 gsl I had owned prior.
Now,2 years later,my car has been at a shop getting the 13b turbo engine,trans,and haltech among other things..I am just waiting for the driveshaft to come back and its done..Now my question is,I'm probably going to try to fix this myself and I'm just looking for some advice on what to do here..If its a bad diff I'd prefer to be able to do some sort of upgrade while I'm at it,either gearing or better lsd,and if I could swap it in and out as one peice that would be even better..Any tips or suggestions would be greatly appriciated..
Old Oct 6, 2003 | 01:10 AM
RacerX7fb's Avatar
paradox
The SE diff does not have a tight LSD compared to the GSL to be begin with.. rebuild it replacing and/or adding the necessary clutch plates then youll have both tires grabbing.
Old Oct 7, 2003 | 01:25 AM
Hey thanks for the input!! But I would really like to be able to just buy a unit and swap so theres less downtime..I don't actually have a garage yet Are there any interchangable units other then the $$ quaiffe,ect.??
Old Oct 9, 2003 | 11:21 PM
Anyone??Whats the easiest way to get my diff working again??I'm gonna need it now that its turbo!!
Old Oct 9, 2003 | 11:25 PM
680RWHP12A's Avatar
wow i didn't know that!!
so the best solution for him would be to swap out his unit with a GSL unit!
Old Oct 9, 2003 | 11:43 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Tightening up a 1st gen diff isn't terribly difficult, even GSL-SE!@@!!
http://www.mazdamotorsports.com sells oversize diff clutch friction discs that can stiffen up your LSD as tight as you want.
While the diff is apart I'd reccomend new pinion, side and axel bearings and a pinion crush tube for reliability and long life. 4.444 gears are great for the street, really let the motor rev up fast and available @
http://www.mazdamotorsports.com also.
Of course you must auto-x twice a year to become a member, but if you don't and speed is of the essence and you don't mind paying full retail price, contact http://www.sevensonly.com and they can set you up @ full retail price.
FWI a stock 1st gen LSD breaks loose @ 90psi torque and the super duper race only stiff LSD on my car breaks loose @ over 175psi ! ! ! ! ! ! ! ! ! !
Brad
Michael Mansour
Aug 18, 2015 03:13 AM
