Would you install this hood?
Old Oct 2, 2003 | 11:32 PM
luiml73's Avatar
Rotary Powered Boobies
1. If they sold this hood for Fb's would you install it?
2. Do you guys think its possible to just make one with some fiberglass.
I happen to like the hood, plus it's funtional. I know this guy who's really good whith fiberglass, and thoughy maybe he can coypythe design.
Just anted to get your opinions!
Thanks
Luis
Old Oct 3, 2003 | 12:41 AM
RotorMotorDriver's Avatar
Seven Is Coming
I personally dont like the vent look. Im more for the scoop look, unless its REALLY cool.
~T.J.
Old Oct 3, 2003 | 01:16 AM
kettlman's Avatar
THE ONE. THE ONLY!
what good does it do for performance?
looks wierd.
Old Oct 3, 2003 | 01:34 AM
but when it rain or snow , ice.. i dont think my rotor will enjoy to have all thise **** water and ice on you ..
Old Oct 3, 2003 | 01:53 AM
Seven Is Coming
looks wierd.
Faster moving air over the top of the vent makes a vacuum inside the engine bay and draws hot air out as I understand it.
~T.J.
Old Oct 3, 2003 | 03:53 AM
MarkPerez's Avatar
Tennis, anyone
You use some kinda-fine mesh screen mounted on the underside of the vent's opening, to sort-of keep ****
out, but not liquid's (water) will get right in. That is a big-*** vent, in that hood.One would think, that a style,any style will look ok on a 1st gen, then you see, or it 'comes' to you, that allthough the 1st gens hood, fender,profile is very simple, only a couple of,vents/scoop really look right. IMO
Old Oct 3, 2003 | 04:51 AM
luiml73's Avatar
If you look closely, you can see the fan. In the angle that it sits, im sure it blows all that heat right out of the engine bay. Since I'm instaling a FMIC, i have no need for a "ramair" hood.
Since they dont sell hoods for our cars here in the US or canada, I guess were going to have to fabricate our own.
BTW: I don't think it'll be snowing any time where I live
Old Oct 3, 2003 | 05:35 AM
Hyper4mance2k's Avatar
The Shadetree Project
i'd hit it. no really, i like it i'd like one!!
Old Oct 3, 2003 | 07:26 AM
pillage6's Avatar
It rains a lot where I live, I would worry about water in my engine bay.
Old Oct 3, 2003 | 11:10 AM
kuhlrx7's Avatar
Unconfirmed
man that hood is great !!! there are several people that are looking for a vented hood simlar to that. I am 1. DF is looking for one also he posted a simlar post a couple of weeks ago. here are a couple of pics that I have found for a first gen
Old Oct 3, 2003 | 11:14 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Negative.
Old Oct 3, 2003 | 11:24 AM
Rx7carl's Avatar
Airflow is my life
Did you guys see moremazdas hood? He did his own mod and the vent is lookin good. The rad supports are removed and it looks like hes using a 2nd gen rad setup.
Old Oct 3, 2003 | 11:29 AM
RXTbone's Avatar
Certainly not daily driver material - cool hood, though.
Old Oct 3, 2003 | 11:38 AM
kuhlrx7's Avatar
Unconfirmed
here is another pic
Old Oct 3, 2003 | 01:41 PM
riffraff's Avatar
smog nazi destroyer
another option for a vented hood is something like the mazdaspeed hood for the third gens.
it can be seen here
http://66.216.67.51/product.asp?0=203&1=357&3=783
Old Oct 3, 2003 | 07:57 PM
toxic_d's Avatar
I'm looking to fab something like that up in the near future (the next 6 months or so). As well as the full custom wide body kit.
Old Oct 3, 2003 | 09:36 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
i like the vent idea.... great way to get the hot air out and if you do it right infront of the motor and behind the rad then nothing gets wet man that vent is HUGE a can cat would crawl in there.
Old Oct 3, 2003 | 11:11 PM
firstgen82's Avatar
i think i rather have a carbonfiber hood instead..plus, won't propping the hood latch do the same thing?
Old Oct 4, 2003 | 06:20 AM
Now imagine this in carbon fiber on a whiteFb like mine ohhh my gawd soooo hot!!!!
Old Oct 4, 2003 | 09:59 AM
moremazda's Avatar
Gone Race'n
It's acctually a stock GSL-SE radiator, and I had to make mounts to hold it where it is.
Thanks for all the advertisement Carl, and I did find your buisness card, so here is a hello back to you!
Ryan
Old Oct 4, 2003 | 10:12 AM
moremazda's Avatar
Gone Race'n
No, popping the hood latch will allow the air building up at the base of the windshield to enter the engine bay. You will be inducting cool air into the engine bay (on it's own merit, good) and increasing the air pressure inside the engine bay, which is the complete opposite of a vented hood.
The purpose of a vented hood is to use the low pressure area on top of the hood to "draw" hot air out of the engine bay. Effectively reducing the air pressure in side the engine bay and sudsequintly behind the radiator...... Now at speed you have a higher pressure area in front of the radiator than behind. If you throw in the vented hood the lower pressure area behind the radiator becomes even "lower". Now the high pressure area has then need to fill that void even more moves at a faster rate, therefor more volume moves through the radiator, and voila more effective coling from the same radiator.
Thanks for listening,
Ryan
Old Oct 4, 2003 | 10:57 AM
Rx7carl's Avatar
Airflow is my life
Ryan
Cool
Well its comming along nicely, so why not give a to you
Yea you werent by your car to say hi so I just left a calling card.
Old Oct 4, 2003 | 10:59 AM
Rx7carl's Avatar
Airflow is my life
Ryan
Well said. Another benefit is that the high pressure air is now exiting out the top of the hood instead of going under the car, means that it lowers the air pressure under the car, reducing lift, giving more front downforce.
At my last track day, there was a guy with an NSX with this setup and he said it produced noticeablly more front downforce, even though it wasnt completely finished and sealed up.
Old Oct 4, 2003 | 11:31 AM
Makwana's Avatar
That hood looks really good if you guys find out who sells them and what not, that will be really cool.
Old Oct 4, 2003 | 10:54 PM
MarkPerez's Avatar
Tennis, anyone
The vent itself is really nothing more then just cutting
the hood 3 times, but whats more important is,,where !
one cuts 3 times...yep.. the stuff that you see 'on' the hood(outside) is just 'extra' aero-styling, oh. i'm sure that ,,that small 'lip' around the vent does effect some ,
but thats one way to make a huge hole in your hood not look so bad. I'm all about vents,, i think if done well the vent(s) look ******* killer. Thats one reason i say 'mariah' they've been there, and. Done that . the body 'kit' on that blue 3rd gen looks like a RE Armiamia ....,,.,...,.,.something,...
