having trouble taking out the auto trans rear counterbalence weight
Old Oct 2, 2003 | 10:45 PM
Gregs's Avatar
Hey, i cant get the rear counterbalence weight off my rex.... i had a puller kit but i could only get the bolts into the weight like 3 threads and the threads on the bolt broke off.. it didnt hurt the threads on the weight though the pulle i used kind of chipped up inside where the pilot bearing goes... its not bad at all, nothing a little filing wont fix...i hope.....
any tricks on how to get the weight off.. its on there REALLY tight...
-greg
Old Oct 3, 2003 | 12:19 AM
Jeff20B's Avatar
Lapping = Fapping
You've already gotten the big nut off, right? If so, just take a claw hammer or whatever (it's got to be metal) and give it a couple good blows. It has always worked for me to remove rear counterweight. Just leave the nut on a couple threads so when the weight slips off its taper on the shaft, it won't fall on the ground.
Incidentally, I just installed a counterweight a little while ago. I'm not sure if it's tight enough. I've got to bolt on a flywheel and a flywheel stopper tomorrow and double check it.
Marty RE
Aug 13, 2015 11:19 AM
