Pressurized gas tank - what gives?
Old Sep 30, 2003 | 07:58 PM
Critoris's Avatar
My car runs fine, but when I fill up the tank hisses and I can see distortion on the grond from the vapor. That's why I think it's pressurized rather than under vacuum. What's up?
Old Oct 1, 2003 | 06:18 PM
Critoris's Avatar
okay, so i filled up today and it's definitely pressurized - not a vacuum. any idea what would cause this?
Old Oct 1, 2003 | 06:21 PM
10sec rx7's Avatar
blocked breather,
if get under the car inbetween the diff and fuel tank on the floor pan you will see a valve and a line that wiggles its way around the floor pan, this is the breather, make sure it isnt blocked or crushed, this also goes to the charcol canaster,
Dale
Old Oct 2, 2003 | 04:16 AM
Critoris's Avatar
okay, so is it an emissions thing that i can get from autozone, or what?
Old Oct 2, 2003 | 10:03 AM
bliffle's Avatar
I thought they all did that: some modern emissions control thing. Shouldn't it hiss? I can't think of a car I've owned in the last 20 years that hasn't done it.
B
Old Oct 2, 2003 | 12:25 PM
Rx7carl's Avatar
Airflow is my life
Read the manual. It should hold a small amount of positive or negative pressure before venting it to equalize with atmosphere. If the vent valve 10sec mentions fails, or the charcol cannister gets clogged, then itll allow excessive pos and/or neg pressure to build up.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
13
Jan 9, 2018 11:19 AM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:09 AM
