Pistons sticking to rotor... fixable??
Old Sep 26, 2001 | 06:14 PM
Icemark's Avatar
Maybe both... also sounds like you have glazed the rotor and pads.
Calipers should float, so if it is against the rotor, your pad (and maybe rotor) is no more...
Is the rotor real shinny? betcha the pad is too.
Pull the wheel, pull the caliper and check it out
Old Sep 26, 2001 | 08:30 PM
Suparslinc's Avatar
It's Back!
Your caliper is frozen, get a new one.
4-piston caliper will run you about $80 w/core exchange.
If you don't, in time your wheel will make this horrible grinding noise and your rotor will be shot.
Old Sep 27, 2001 | 12:53 AM
Suparslinc's Avatar
It's Back!
Go to any import parts store.
Around here, we have Spradlin and Smyths.
The dealer will be too expensive, but its worth a phone call.
Most anywhere will give you a core exchange.
The trick is finding a ride over there, since you can't drive your car with the caliper off.
Old Jun 5, 2002 | 11:13 PM
Skippydog's Avatar
I am in desperate need of new 4-piston calipers. The only problem is I dont have a local import shop around here. Does anyone know where i can go for new calipers that arnt going to kill me with their prices. Im in need VERY SOON. I just went to replace my pads which are worn right down to the metal. Damn that sucks i had to put them back to gether with the shitty old pads. Two of the pistons are stuck on both calipers. I also need a set of new springs if anyone knows where to get them. Please help!!!
Old Jun 5, 2002 | 11:33 PM
duboisr's Avatar
garfinkle fixed mine by disasembling and cleaning the sticking cal ,he also did the other side as well.It did not cost near $8O . Why do you wont to waste money ? This was several years ago with no problems yet.
Old Jun 5, 2002 | 11:37 PM
Skippydog's Avatar
They are really jamed up. I tried to break the pistons free with a heavy *** hammer and whatever i could find around the garage with out any luck. I even used bolt breaker fluid. they wont even budge. If you have any ideas besides what i tried im open for anything. Otherwise i still need to find a pair of 4 piston calipers.
GKW
Sep 28, 2015 04:34 PM
Devon300zx
Sep 22, 2015 12:07 PM
