Power FC Temp wrong on PFC ????
Old Sep 25, 2003 | 07:11 PM
Maestro's Avatar
My power FC seems to be reading high Water temp its at about 100-107C.
Also the cooling fans come in at 104C ??
Factory guage shows nothing as usual ???
What do you reakon is up with it ???
Faulty water temp sensor ??
Help !!
Old Sep 26, 2003 | 06:04 AM
evot23's Avatar
Classy
Are you sure that you aren't just having high temps? It's possible to have a faulty temp sensor I guess...check the voltage on the sensor if you can.
Old Sep 27, 2003 | 06:40 PM
Maestro's Avatar
Voltage seems okay. Well the PFC hasn't said there is a sensor fault.
Why would the fans come on at 104 thats what makes me think its just reading high ???
Old Sep 27, 2003 | 07:21 PM
rynberg's Avatar
The PFC should default to come on at 99-100C. I don't know why your fans aren't coming on sooner. Check your relays to make sure the fans are operating at low, med, and high speed.
If you have access to a datalogit, you can change the temps the fans come on.
Although, you have some other issue if you are getting temps that high -- bad thermostat or something else.
Old Sep 27, 2003 | 07:22 PM
rynberg's Avatar
EDIT: YOu can also check the voltage the water temp sensor is giving off on the PFC commander. Check it against the service manual.
Old Sep 27, 2003 | 07:27 PM
Maestro's Avatar
Yeah my guess might be a faulty thermostat
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
RE-Mamamia
Sep 11, 2015 02:13 PM
