Sponsored by: CARiD
power loss during hard left turn?
Old Sep 15, 2003 | 12:25 AM
crackavelli's Avatar
My 91 RX-7 convertible has been completely losing power during hard left turns. The power only cuts out for a second. Its happened to me about 4 times now. Any ideas? Thanks
Old Sep 15, 2003 | 10:36 AM
Wargasm's Avatar
Weird Cat Man
This -might- be fuel cut.
On 3rd gens (very similar to your 91), if the fuel tank is low, and you turn very hard left, the fuel sloshes around in the tank and the pickup sucks up air and you lose power. This isn't really good for the car....
See if the situation is better with a full tank vs with 1/4 tank or less.
If this turns out to be the case and it is a new problem, you might want to look inside the fuel tank and make sure your baffles in the tank aren't separated from the tank body or something...
Brian
Old Sep 15, 2003 | 12:19 PM
Thanks for the reply. The first time it happened my fuel was pretty low, in fact I was on my way to the gas station. However, the other three times the tank was at least 1/2 full. Could there be intermittent bubbles in the fuel line from the first incident?
Old Sep 15, 2003 | 01:21 PM
hugues's Avatar
Why am I here ?
Search in the 2nd gen. section
It's probably the in-tank fuel filter that's clogged.
that's a common problem.
Hugues -
Th0m4s
Feb 26, 2019 02:04 AM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
andyvideopro
Aug 11, 2015 09:16 PM
