Which is the weakest 2nd gen rx-7?
Old Sep 24, 2001 | 03:06 PM
Jason Arena's Avatar
Which rx-7 2nd gen is the weakest? also, how does the gxl compare to the gtu and turbo 2.
Old Sep 24, 2001 | 03:59 PM
ZachSpazz's Avatar
I wish I had a posse...
The 'weakest' 2nd Gen is an 86-88 non-turbo.
However if you asked what the slowest 2nd Gen is, then it's the 88 Convertible. It's the heaviest being saddled with the weight of the convertible mechanism.
To answer your your second question, the fastest 2nd gen is the Turbo (obviously). The GXL is slightly slower than a GTU, GTUs, or Base model as it has all the power accessories which add weight.
Old Sep 24, 2001 | 04:47 PM
PraxRX7's Avatar
GX 1986
The 1986 GX i would presume...
But the GXL GX and "SE" Cannot compare to the GTU, GTUs, or the Turbo II...there just isn't any comparison.
Old Sep 24, 2001 | 06:54 PM
Mykl's Avatar
Mine is, or at least it feels like it.
Needs a turbo pretty badly.
Old Sep 24, 2001 | 07:12 PM
MaxRX7's Avatar
hambre y sueño
it is simple: power to weight ratio
the 86-88 N/As had the least HP
the 'vert has the most weight
therefore, the 86-88 'verts are the weakest *ahem* not neccessarily but they are the "slowest", especially automatics(plus the tranny is also heavier).
Old Sep 25, 2001 | 08:08 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Ummmm... there aren't any 86-87 convertibles.
Old Sep 25, 2001 | 09:50 PM
fc3s.org's Avatar
OG
When comparing all the FC's in stock trim, the 88 automatic transmission convertible is the weakest link
