Racing Hart C2
Old Sep 13, 2003 | 11:28 AM
transcendmedia's Avatar
They Call Me The Closer
Racing Hart C2
What is the widest C2 wheel that go on an 94? Front/Rear? Also, what tire would you recommend for the car? I was looking at the Proxie T1-S but I'm not sure if a higher rated tire would be recommended. I was also looking at the Racing Hart CP-035R Wheels with sizes of 18x8.5 , 18x9.5" in the front & rear respectively. I was told these fit fine with a FD with 245 & 275 tires.
Thanks all for your help, it was greatly appreciated.
Old Sep 13, 2003 | 01:09 PM
rynberg's Avatar
You should look in the suspension forum archives, there's all the info you need.
If you run 18x8.5 and 18x9.5, you will want offsets in the +40 to +50 range. Tire sizes would be 235/40 or 245/35 front and 265/35 rear.
You could also run 18x9 all around with +45 to +50 offsets. Tire size would be 255/35 all around.
As an extreme fitment, you could also run 18x10 rears, +45 to +50 offset, with 285/30 tires.
The Toyo T1-s is an excellent tire and one of the lightest tires around.
Old Sep 13, 2003 | 02:53 PM
Thanks for the reply!
Will there be any problems such as rubbing, running the 18x8.5 and 18x9.5 with the 245/35 front and 265/35 rear tire sizes?
Thanks again!
Old Sep 13, 2003 | 03:08 PM
rynberg's Avatar
There shouldn't be if the wheels have the offsets listed above. If you lower the car though, you may or may not experience rubbing, everyone's car is a little different. But those are pretty "safe" recommendations.
Old Sep 14, 2003 | 02:43 AM
al4t1gbundy's Avatar
wat rynberg said
