Sponsored by: CARiD
Building a 13B for turbo application
Old Sep 11, 2003 | 10:57 PM
amused's Avatar
My car runs great. The 13BT in there has 30k from a Mazda reman that the last owner did on it.
However I'd like to learn how to rebuild/build my own 13B, with low compression rotors so that my upcoming T04 project will have a proper home. This will be a side project that I can work on to futher my knowledge of rotaries. They say there's no better way to learn then by firsthand experience.
Can a knowledgable person please list of the parts I will need to build a full 13B block? I'm dreaming of something close to 8.5:1 compression.
Thanks!
Old Sep 12, 2003 | 02:07 PM
wwilliam54's Avatar
it WILL run
get a jdm t2 block
it will have the right rotors and houseings, and be cheaper to beef up
Old Sep 22, 2003 | 11:07 AM
RETed's Avatar
Check out Mazdatrix, they can help you out with all the parts listings...
http://www.mazdatrix.com/
BTW, JDM FC blocks come in both Zenki and Kouki flavors.&nbsp The Zenki ones are 8.5:1, but the Kouki ones are 9.0:1.
-Ted
Old Sep 22, 2003 | 05:41 PM
wwilliam54's Avatar
it WILL run
right
get the s5 one if you can
9:1
Old Sep 23, 2003 | 05:59 PM
RETed's Avatar
Not necessarily...the Zenki FC turbo rotors are stronger, and if the person is going to run high boost (over 25psi), it's recommended to run the Zenki turbo rotors.
-Ted
Th0m4s
Feb 26, 2019 02:04 AM
Machupicchu
Aug 17, 2015 08:27 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
