Rear Brake Caliper?
Old Sep 11, 2003 | 10:49 PM
daem0n's Avatar
RE-Amemiya in the blood
Question Rear Brake Caliper?
Do you guys know what the part number is for the rear left brake caliper? How much would a rebuild be and where can I get one? Also, how much would a new one be approximately? I think my caliper is seized and am weighing out my options. How can you test to see if the caliper is seized? It's constantly dragging against the rotor and has done so much that I now need to replace the rotor because it's warped/worn it down. Thanks for any suggestions, -Joe
Old Sep 12, 2003 | 04:10 AM
maxcooper's Avatar
WWFSMD
If you have the urge to upgrade, take a look at the Group Buy section for the bigger Mazda RS/RZ brake group buy. dclin and the RX-7 Store have worked out a special price for the Mazda parts (calipers, pads, hardware) and dclin also lined up a supplier for 2-piece rotors, all at very good prices.
https://www.rx7club.com/forum/showth...hreadid=219291
The group buy ends today (Friday), so act fast if you are interested.
-Max
Old Sep 12, 2003 | 10:43 AM
SleepR1's Avatar
Off topic...Hey maxcooper, was checking out your website. You sure your 9.5 x 17 Volk SE37s are only 10-1/8 inch wide in overall width? Seems a bit narrow for 9.5s?
Old Sep 12, 2003 | 12:26 PM
daem0n's Avatar
Hey Max, thanks for the heads-up. Definitely looks like a good deal for the money. Unfortunately I probably can just afford a new stock caliper right now. CDN versus US pricing is still pretty bad after duty and exchange unfortunately.
Old Sep 12, 2003 | 10:17 PM
daem0n's Avatar
Re: Rear Brake Caliper?
Old Sep 13, 2003 | 05:48 AM
maxcooper's Avatar
WWFSMD
Yeah, I think I measured that one wrong. I'll change my web site now...
-Max
Old Sep 13, 2003 | 06:52 AM
SleepR1's Avatar
-Max
Well, I got excited about running 9.5 x 17 all around with 40-mm offset, but...I guess I'll be going with 9s all around, like TAZ's setup, except I'll have Titanium Silver finish with semi-gloss...instead of black...
Old Sep 14, 2003 | 01:44 AM
daem0n's Avatar
Aaaaaaaaaaaaanybody at all?
Old Sep 14, 2003 | 07:13 PM
maxcooper's Avatar
WWFSMD
Try one of those places that sells reman car parts on the internet. http://www.partsamerica.com has them for about $105, and I think you can pick it up from a local Kragen/Checker/Schuck's store. Perhaps it would be best to arm yourself with knowledge of the online price and then just go to the auto parts store to see what they can do. You could save on shipping, you might get it faster, and it would be easier to return to the store if something isn't right. Dropping off your old caliper for the core charge will be easier also.
NAPA Auto Parts seems to have them even cheaper -- about $80. Go to whatever auto parts store you have locally and order one. The price should be the same as the store's online price (NAPA online should match NAPA in-store), but it would be wise to know the online price just to make sure they don't try to gouge you.
You want an "unloaded" caliper if you already have pads you want to use. This is what I recommend (as opposed to a "loaded" caliper, which means it comes with pads), especially if you will just be getting one caliper. Even if you were getting two calipers, I'd rather buy some pads I am familiar with separately.
-Max
Old Sep 14, 2003 | 11:52 PM
daem0n's Avatar
Hey, thanks a lot Max. Helpful as always -Joe
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
