Sponsored by: CARiD
Car is running bad please help
Old Sep 11, 2003 | 11:02 AM
jonm16's Avatar
Hi all, recently my car was flooded and I did the egi comp fuse trick and it worked and started fine after that. Now however whenever I drive after about 10-20 minutes the idle starts bouncing erraticly and when I step on the gas the rpm goes to like 3k and doesn't go any faster. It also runs very rough hesitated and stuff. What could this be? Can it be I need to change the oil after unflooding the engine? Any help would be appreciated as this car is all I have to go to work and school.
Thanks
Jon
Old Sep 15, 2003 | 12:57 AM
SmoovRex's Avatar
Newbie
i got tha same exact problem.. Let me know when u fix it and wat it was cuz its kinda leavin me clueless too.. was thinking about timing mostly but give me a holla when u figure it out, id appreciate it alot. My email is Rooflz@aol.com thankz alot man, much appreciated
Old Sep 15, 2003 | 08:40 PM
SmoovRex's Avatar
Newbie
i looked all threw this website and found no help on this subject so now i will turn to yall (tha rotary Guru's) to answer tha problem that jonm16 has posted.. but tha story getz bigger check it out.. While tryin to get tha car to run right today. Its an 87 Se (13b) and i found a sensor with tha end of it melted off.. Like really burn burnt like someone took a torch to it or something.. But tha 2 wires that go to it are not connected and here are some pics of it..
This one shows how burnt it is where tha other wires connect to tha sensor, tha otha end is where it screws into engine..
Old Sep 15, 2003 | 08:44 PM
SmoovRex's Avatar
Newbie
maybe this will work...
sensor 1
sensor 2
sensor 3
Old Sep 16, 2003 | 12:50 AM
Sinful7's Avatar
Maybe you could try to reset the ecu by disconnect the battery, I had this happen to me when I pulled the fuel pump relay to unflood the car. Not sure if this will help you but hope it works.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
Marty RE
Aug 29, 2015 07:51 AM
ashleymiche
Aug 14, 2015 12:59 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
Wolf_
Aug 11, 2015 04:23 PM
