clutch problem
Old Sep 9, 2003 | 07:26 PM
xlversatilelx's Avatar
clutch problem
when i go to drive my car the clutch pedal is really soft and ****. like hteres nothing there i have to pump it for awhile for it to get hard and to grab. what is the problem here?? and i rarly drive my car could that be a factor?? because i dont drive it as much??
and i was thinking about getting a new cluth what do you guys perfer on upgrading to??
thanks ..
Old Sep 9, 2003 | 08:02 PM
BigJim's Avatar
trainwreck
well i had the same prob as u, check ur clutch fluid, it uses dot 3 or 4 brake fluid, if its low fill it pump it and check it hte next day. If its low again then u should probably replace your slave cylinder, its like 19 bucks and real easy to install
Old Sep 9, 2003 | 09:25 PM
Bass's Avatar
Grey-Bruce Rotorhead
I had the same thing happen a couple of years ago. I had to change the slave cylinder because it had a small leak. You might as well change the master cylinder at the same time as it will soon fail. It's an extremely easy job to do. It took about an hour and a half from start to finish (including finding the right sockets that never seem to make it back into the tool chest.) The toughest part is getting at the bolts for the master cylinder. I put the driver's seat all the way back and reclinded it as far as possible. Then you climb in upside down so that your feet are at the headrest. The head rush you get is free- enjoy!
Old Sep 9, 2003 | 09:30 PM
mwpayne's Avatar
Admitted 'rexaholic'
If you go to sears or somewhere and pick up one of those swivel thingys to go on your socket wrench, that top master bolt is MUCH easier!
Old Sep 10, 2003 | 02:31 AM
aighte ill check it but i rmemeber my fluid was full, so would it just be the slave cylinder that needs to be replaced or both, and do you knoe where i can get one ? thanks
Old Sep 10, 2003 | 06:09 AM
mwpayne's Avatar
Replace both..if you don't I guarantee that the other will go bad in a month. I got mine at Advance Auto.
Old Sep 10, 2003 | 07:26 AM
erick1120's Avatar
Have you tried bleeding the system yet. It might need that and also check the free play on the pedal.
Enzo1944
Sep 6, 2015 08:57 AM
vmerino
Sep 5, 2015 11:26 AM
