Oil Hose??
Old Sep 8, 2003 | 11:00 AM
KritterMac's Avatar
Oil Hose??
This is for you 12a buffs in here. I went to town today and discovered my 85 had a major oil leak. Before deciding to go the pit for her final farewell, I decided to take it to my mechanic just to see....GOOD IDEA!! Come to find out it's just a hose that goes from the front of the engine( possible the oil pump?)to the back of the engine.(possibly a cooling system?) My question to you is...what is that hose called so I can order a new one. Thanks guys and gals.
Old Sep 8, 2003 | 11:11 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
Check this link out:
http://www.wankel.net/~krwright/cars/rx7/85_manual.html
Find the hose in the manual, then you'll have a mazda part number that you can order with.
Old Sep 8, 2003 | 11:27 AM
MarkPerez's Avatar
Tennis, anyone
That is a 'hardline' from the front to the rear. it's for oil.
you can , in most cases find one at a junkyard for cheap.
you DO need it though.
Old Sep 8, 2003 | 11:40 AM
KritterMac's Avatar
Is it a oil cooler line??
Old Sep 8, 2003 | 12:13 PM
erick1120's Avatar
I got a running engine out of a bone yard that had it replaced with a flexible line. It was on an 83 with the behive oil cooler. You may want to look into having one made with the fittings on the end of it. I don't know if it would be cheaper or not. Apparently it works it you have the right type of hose. The engine was running fine when pulled.
Old Sep 8, 2003 | 01:11 PM
MarkPerez's Avatar
Tennis, anyone
Yes, it is a oil cooler 'hardline'
rotor_veux
Sep 3, 2015 07:10 PM
