Sponsored by: CARiD
Slick 50 in rotary?
Old Sep 23, 2001 | 04:49 AM
Locutus's Avatar
Question Slick 50 in rotary?
Is it advisable to use Slick 50 or similiar products in a
rotary engine? Will it do any good?
Old Sep 23, 2001 | 10:30 AM
matt007's Avatar
My guess is that it would do more bad than good
Old Sep 23, 2001 | 02:03 PM
maxcooper's Avatar
WWFSMD
Don't put Slick 50 in any engine. It doesn't work, and the Slick 50 company has been sued several times (and lost, I think) because it is not good for the engine. DuPont (makers of Teflon, which is Slick 50's star ingredient) says that the material should NOT be used in internal combustion engines.
If you want to do something special for your engine, pre-mix a little two-stroke oil in the gas. That would give far better protection than any of the snake oils.
-Max
Old Sep 23, 2001 | 03:48 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Yeah, I agree. Not only are they generaly not that good for mos internal-cumbustion engines, but they are especially bad in rotaries due to the extra high engine temps, and the oil injection system. The stuff leaves carbon deposits when burned, so it's a BIG no-no.
Two stroke is good and, if you can find it, pick up a bottle of Lucas Fuel Treatment. Works great!
Old Sep 23, 2001 | 08:59 PM
Icemark's Avatar
Slick 50 worked when it was made in CO, but when they sold it to Quaker state it became snake oil with teflon and Parafin based snake oil at that.
Either way you are better of not using it in a rotary or any car anymore.
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
rx7jocke
72
Jun 17, 2016 03:48 AM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
