Sponsored by: CARiD
counter weights
Old Sep 5, 2003 | 11:56 AM
EProdRx7's Avatar
counter weights
How can I determin if the counter weights, front and rear, are from an 89-91?
Old Sep 5, 2003 | 12:32 PM
spunks's Avatar
Part numbers.
Old Sep 5, 2003 | 01:43 PM
EProdRx7's Avatar
No realy? problem is, that I have a bunch of them without part#'s on them smart ***. I'm looking for visual clues...
Old Sep 5, 2003 | 03:29 PM
FxF's Avatar
FxF
Dorifto Tengoku No More
Aren't they the same?
Did you do a search?
Old Sep 5, 2003 | 03:43 PM
spunks's Avatar
s4 and s5 counterweights are different.My s4 counter weight has only one hole drilled into it.Weigh them and see if they have a different weight to them.Because they all look alike visually.
Old Sep 5, 2003 | 04:28 PM
rotarygod's Avatar
Rotors still spinning
The counterweights are visually identical. The holes drilled in them mean nothing in terms of determining which years they are. The '89-'91 counterweights are lighter than all the earlier ones but only very slightly. It would take a postal scale to see the difference. I had this scenario several years ago with 2 different counterweights during a rebuild. I flipped a coin and hoped the engine wouldn't shake when started up. I got lucky. Unfortunately I don't really have anything helpful to tell you.
MILOS7
May 9, 2016 06:39 AM
Vartok
16
Oct 8, 2015 04:49 PM
