pressure plate bolt tightening sequence?
Old Sep 22, 2001 | 05:24 PM
Christopher's Avatar
Can someone tell me or show me the bolt tightening sequence when bolting up the pressure plate and clutch to the flywheel. I can't find my Chilton's and the shop manuals online don't seem to provide them.
Thanks,
Christopher
Old Sep 22, 2001 | 05:38 PM
BLUE TII's Avatar
Rotary Motoring
Tighten all finger tight, slip in cluch alignment tool and center disk, tighten bolts to torque values over several steps in a crisscross fashion.
Old Sep 22, 2001 | 06:28 PM
Thank you very much!
Old Aug 19, 2004 | 08:34 AM
DerangedHermit's Avatar
I put in the clutch alignment tool first then put the PP on. Worked good for me. The general rule for tightening anything is screw the bolts/screws/whatever with your fingers, then go into a cross pattern.
Old Aug 19, 2004 | 10:04 AM
SureShot's Avatar
Seduced by the DARK SIDE
Most clutch alinment tools have more play & flex them your input shaft.
After you start to bolt down the pressure plate, look carefully through the clutch spline to the pilot bearing seal to verify it's exactally centered.
I had to remount my clutch twice before I had it straight enough to fit together.
Old Aug 19, 2004 | 10:32 AM
I didn't check mine because I'm retarded but I'm putting in a new tranny this weekend anways, good time to do it.
