Sponsored by: CARiD
Driveshaft
Old Aug 27, 2003 | 04:08 PM
Keisuke T.'s Avatar
Driveshaft
How do you know if the U-joint is bad in a driveshaft? How do you fix it?
Old Aug 27, 2003 | 05:10 PM
Project84's Avatar
Open up! Search Warrant!
Hold one side still and shake the other side. If the u-joint moves its bad. Hard to explain without having you see what movement is bad. Also, if it binds up or doesn't flex freely, it should be replaced. Or if it breaks(obviously).
Old Aug 28, 2003 | 08:30 AM
Keisuke T.'s Avatar
So you're saying if I pick it up and it jiggles freely like a limp dick it's probably bad.
series1rx7
Sep 27, 2015 05:46 PM
