Turbo Lag
Old Aug 23, 2003 | 06:26 PM
Louis M's Avatar
Turbo Lag
Alright, I know this sounds stupid, but I've never understood this phrase. Does this mean that if a turbo doesn't engage until 5K, it lags more than one which engages until 3k? Or is is just that when you reach 5k it takes two seconds until you go to 5.1k, or what?! SO CONFUSED!
Old Aug 23, 2003 | 08:28 PM
IRPerformance's Avatar
Sponsor
Its generally refered to the delay from when you press the gas to when boost comes on.
Old Aug 23, 2003 | 09:47 PM
HWO's Avatar
HWO
inteligent extratarestril
nope, you are talking Turbo Threshhold
Lag is the time taken to reach 'certain boost level'? once you are above the turbo threshhold rpm.
Most people think turbo threshhold is actually LAG, when it most certainly isn't
Old Aug 23, 2003 | 11:06 PM
Louis M's Avatar
so i was right, lag is just time it takes to reach 5k rpms or something
Old Aug 24, 2003 | 01:26 AM
maxcooper's Avatar
WWFSMD
You don't quite understand yet.
If you are cruising at 5K RPM under light throttle (no boost) and then mash the throttle, turbo lag is the time it takes for your boost pressure to rise to the maximum level. Say it takes 1 second before you hit your maximum boost of 15 psi. That is turbo lag. It doesn't have much to do with engine RPM.
If you mash the throttle at 1000 RPM, you won't get any boost. But if you keep your foot on the floor, there will be some RPM at which you reach your maximum boost. That is NOT turbo lag, but rather the threshold thing that HWO is talking about. Again, this is NOT turbo lag.
-Max
Old Aug 24, 2003 | 02:11 AM
GoRacer's Avatar
Speed Mach Go Go Go
wow, no wonder I never understood what people were talking about when they mentioned lag. I allways thought it was from NA to when the turbo "began" to kick in.
Old Aug 24, 2003 | 05:01 AM
HWO's Avatar
HWO
you will find people talking about their turbo being laggy, when in fact they dont even know what turbo lag is
Old Aug 24, 2003 | 09:09 AM
Louis M's Avatar
See what I mean? The phrase is easily tossed around but no one knows what it correctly means! BTW, does anyone have any videos of their car with turbo lag? Just to see it and understand it... Thanks!
Old Aug 24, 2003 | 11:45 AM
maxcooper's Avatar
WWFSMD
It is very easy to experience... just follow the procedure in the second paragraph of my last post. Cruise at 5000 RPM (no boost) and then stomp on the gas pedal. The tme between the stomp and reaching maximum boost is the lag. Do you have a boost gauge? That will help illustrate what you are experiencing.
Generally, though, I agree that the term is used loosely. Car magazines often use "lag" to describe when the boost comes in (threshold). The two things are also somewhat related -- turbos with a low threshold often have less lag than turbos with a high threshold. It is also hard to quantify, and thus compare from turbo to turbo. Lag changes with the weather, RPM, etc.
-Max
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Clacor
Aug 14, 2015 09:17 AM
