Aquamist 2d Install
Old Aug 23, 2003 | 10:08 AM
LUV94RX7's Avatar
Oldie, but Goodie
Aquamist 2d Install
I attached some pictures of the 2d install.
I am using the .9mm water jet at this time.
We set it up to inject water starting at 5 psi.
As you can see by the pictures everything needs to be cleaned up and made look nicer. This was right after we got done.
Steve Kan missed his flight out of Dallas. He had to scramble around for another flight and he was 7 hours late. We arrived at my brother's home for the install and we started at 10:00pm. We were done at 2:00am. Steve did a fine job considering he never saw the kit before or installed water injection on anything.
The next day did some more work on Damian's car and I lead them to the dyno site for tuning on Damian's car. In the drive to the dyno I was leading them to, I was cruising along and my intake air temps as measured by the PFC Commander was 51C. Damian passed me for fun, I guess, and I had to kick it in to catch up. I boosted to about 10psi and the air temps dropped to 30C, so water was working.
Here again thanks to all involved.
Ken Francis
http://mywebpages.comcast.net/luv94rx7/AQUA1.JPG
http://mywebpages.comcast.net/luv94rx7/AQUA2.JPG
http://mywebpages.comcast.net/luv94rx7/AQUA3.JPG
http://mywebpages.comcast.net/luv94rx7/AQUA4.JPG
http://mywebpages.comcast.net/luv94rx7/AQUA5.JPG
http://mywebpages.comcast.net/luv94rx7/ENGINEBAY.JPG
http://mywebpages.comcast.net/luv94rx7/FUELCELL.JPG
http://mywebpages.comcast.net/luv94...KAN-INSTALL.JPG
Old Aug 23, 2003 | 10:44 AM
vosko's Avatar
Just Call Me Terminator!
sounds good. i'd like to do that eventually when i have some spare $$$
Old Aug 23, 2003 | 10:46 AM
Resource's Avatar
what's all that crap http://mywebpages.comcast.net/luv94rx7/FUELCELL.JPG
Old Aug 23, 2003 | 11:11 AM
7racer's Avatar
Good job!
i'm really excited to hear about your dyno tuning....when is Steve getting that on the dyno?!?
Congrats!
Old Aug 23, 2003 | 01:52 PM
LUV94RX7's Avatar
Oldie, but Goodie
http://mywebpages.comcast.net/luv94r...AN-INSTALL.JPG
Maybe this one works.
Old Aug 23, 2003 | 01:55 PM
LUV94RX7's Avatar
Oldie, but Goodie
Stuff, hood scoop is a maybe future project.
Put it on in reverse and cut 4 big holes in hood to suck hot air out of engine bay while moving and let it out when at stop sign.
Ken
Old Aug 26, 2003 | 09:58 AM
ZeroBanger's Avatar
Glad you got your WI setup done, I would not be without it. You will be glad you did it.
Old Aug 26, 2003 | 05:49 PM
Chronos's Avatar
I thought you've had WI for a long time Ken? BTW, are you injecting in the hot side of your IC endtank?
Old Aug 26, 2003 | 07:26 PM
LUV94RX7's Avatar
Oldie, but Goodie
Just after the SMIC. I had the 2s kit installed. KDR was not able to program it due to their dyno breaking and I could not figure it out so I went the simple route of the 2d kit which needs no programming. Just set the boost to kick in and pick the right size water injector.
Ken
Old Aug 28, 2003 | 02:55 AM
Chronos's Avatar
I can't tell from the picture, where is the water being injected?
Old Aug 28, 2003 | 05:44 AM
LUV94RX7's Avatar
Oldie, but Goodie
Water pump is on the left in front of the K&N filter, plastic water tube goes over K&N, over the electric IC fan and injects water into the pipe right after the exit of the IC. The brass fitting farther up is an air temp probe just before the GReddy elbow.
Ken
Old Aug 28, 2003 | 02:15 PM
Chronos's Avatar
Nice...beautiful setup you have there!
Old Aug 28, 2003 | 09:45 PM
87GTR's Avatar
I have dual 2s system that I still have not had time to install maybe soon
Old Aug 29, 2003 | 09:10 AM
RXTASY1's Avatar
Here is mine.
http://www.teamfc3s.org/forum/showth...&threadid=9692
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
