Haltech haltech manual wrong?
Old Aug 22, 2003 | 06:50 PM
platinumblack's Avatar
i have an e6k version 1.0 manual and on page 125 it shows hookups for rotary direct fire ignitions.it shows:
DIGITAL OUT 1 - trailing spark FRONT rotor
DIGITAL OUT 2 - trailing spark REAR rotor
i used one of the rx7 to e6k wiring diagrams off someones site for help when installing it myself and IT shows:
digital out 2 FRONT ignitor
digital out 1 REAR ignitor
these are conflicting so can someone tell me if the manuals wrong or the diagrams wrong?does someone have a newer manual.thanks
Old Aug 22, 2003 | 07:23 PM
tims's Avatar
for my E6K installation using second gen coils. I have the leading coil(pink wire) connected to ign out(L. grn) and trailing I have white wire(from coil pack) connected to auxillary out(grn/blk) and pink wire(from coil pack) connected to dig out 1(wht/blk). tan wire on both coil packs to 12vdc, black on trailing coil to ground on harness wiring and to body ground. yellow on trailing coil can be used for tach signal.
Old Aug 22, 2003 | 09:21 PM
i have an fd,of the pink and white wires,which one is front and which one is rear
Old Aug 22, 2003 | 10:35 PM
rxrotary2_7's Avatar
https://www.rx7club.com/forum/showth...hreadid=198578
Old Aug 23, 2003 | 01:04 PM
rxrotary2_7,i'm not trying to be a dick but again,you list digital out 2 as brown.in my fd manual,brown is front trailing and in the haltech manual it says front trailing should be digital out 1.
Old Aug 23, 2003 | 01:10 PM
also,i cant get my tach to work.i have the lt. green haltech spliced into lt.blue/yellow-2b on oem connector with the connector plugged into stock computer.i have also tried auxillary out but nothing seems to work
Old Aug 24, 2003 | 01:17 PM
tims's Avatar
sorry only have FC. pink is the signal to the coils and the white is the toggle.
Old Aug 24, 2003 | 09:03 PM
cool, so i wont respond and you can figure it out. i typed thatat thread a while ago, and wrote the notes a lot longer ago. i am not going to go back and look through and correct it. if you are right, your right. great
Old Aug 25, 2003 | 06:20 PM
i'm not trying to win a pissing contest,i just want to know if my cars wired correctly.
Old Aug 25, 2003 | 11:12 PM
Carlos Iglesias's Avatar
Corn-to-Noise Converter
Veteran: Navy
Top Answer: 1
NOT to pile on, but...
I just finished my install yeaterday, and my T1 / T2 connections were backwards (as confirmed with a timing light.) This questions validates my concerns.
BTW, I pulled my (FD) ignitor connector, switched the pins (B and BR/B) and the timing gun confirmed the correction.
Old Aug 25, 2003 | 11:53 PM
ok, note to self. stop 'ing when taking notes.
Old Aug 28, 2003 | 08:51 PM
RETed's Avatar
The answer?&nbsp It depends on how you set-up the ignition...
There are ways to actually get the firing order flipped backwards, as there are several ways to "zero out" your ignition system write-up's online.
By changing the tooth offset and trigger angle, you can get it to fire 180-degrees off.
-Ted
Old Sep 9, 2003 | 06:59 AM
thanks for the info ted.
how do i know if its 180 off?i didnt set up the ignition,just copied the numbers.here they are.
tooth offset 5
trigger angle 64
number of teeth 24
Old Sep 10, 2003 | 06:13 AM
RETed's Avatar
Once you have verified the leadings are firing at the correct mark, gun the front trailing - this mark should be very close to the leading mark.&nbsp If you can't see it, try and gun the rear trailing to see if you can see the leading point - if you can, things are obviously backwards.
-Ted
24seven_dada
20
Nov 10, 2018 12:03 PM
