Sponsored by: CARiD
info about Engine
Old Aug 20, 2003 | 04:58 PM
kyuusen's Avatar
info about Engine
Hi guys, i think i'll buy a turbo Fc. How can i reach 300 hp. What are the best mods?
if the engine overheats i have to replace it? Is it true?
Unluckly we don't have REAmemiya in italy...
thx
Old Aug 21, 2003 | 12:09 AM
diabolical1's Avatar
make sure the car gets a full tuneup after you get it.
you'll probably want to start with getting a good exhaust system first, then move to getting a better intercooler.
after that it should be just a matter of turning up the boost and monitoring fuel and ignition as you do so. i'm not sure if the stock S4 or S5 turbochargers will flow enough for a solid, reliable 300 HP - so you should probably check out turbos as well.
however, before you start budgeting for a new turbo, ask around in the Gen II forum - those guys would be better suited to point you in the right direction.
welcome to the forum and good luck.
Old Aug 21, 2003 | 05:33 AM
kyuusen's Avatar
thanks a lot for the infos you gave me diabolical1
in Gen II forum nobody answer me
so last question :P
is the engine really so delicate?
arigatoo
Old Aug 21, 2003 | 12:49 PM
no problem ...
they're not all that nice in the Gen II forum, but don't be discouraged. you can still find ways to get around them and find answers. there is a Single-Turbo forum as well and those guys are pretty good with answering questions.
i'm at a bit of a loss for a couple of reasons. first, i don't know which car you're getting - a Series 4 or 5. and second, i don't know what the differences between the US-spec cars and European-spec cars are in terms of power.
however, you can PM me with any questions you have. if i don't have the answer, there are a few people that i can ask - and if that doesn't work, then i'll do my best to help find a direction in which to point you.
Old Aug 21, 2003 | 04:55 PM
kyuusen's Avatar
thank you very much!!!
and if you'll have the chance to be in Italy gimme a call, i'll be in for a beer
ja na!
elfking
Aug 19, 2015 09:48 PM
rx7jocke
Aug 15, 2015 03:36 PM
