Warning Lite Setting Question?
Old Aug 19, 2003 | 01:20 PM
banzaitoyota's Avatar
What Subscription?
What set-point are you running for your low oil pressure warning lite?
Old Aug 19, 2003 | 09:13 PM
tims's Avatar
50 psi. this is not the sensor that is included in most pre-wired gauge kits though. they usually contain a 5psi or lower switch. when this light(using the 5psi switch) comes on in a racing situation it is to inform you that you need to rebuild your engine. 50 psi will give you time to shut the engine down before all the bearings are ruined
Old Aug 19, 2003 | 09:24 PM
What Subscription?
Thanks, I'll order the 50 PSI switch tommorow
Old Aug 20, 2003 | 02:09 PM
23Racer's Avatar
Oil Pressure Warning Light
Great info. I had never thought of that. Will order a 30 lb switch tomorrow. Still using stock oil pressure bypass.
matty
Jan 18, 2020 10:39 AM
