Don't let this happen to you
Old Aug 18, 2003 | 09:58 PM
erick1120's Avatar
Angry Don't let this happen to you
This is my front rotor
Old Aug 18, 2003 | 10:02 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
damn!
Old Aug 18, 2003 | 10:55 PM
NanaimoRx-7's Avatar
Hot Damn ! Time to make a wall clock, or for super style make a clock out of it and wear it around your neck. Badge of Pride.
Old Aug 18, 2003 | 10:56 PM
Pedestrian X's Avatar
SpAz!
wow, how did you manage that? heh
Old Aug 18, 2003 | 11:08 PM
O 16581 72452 5's Avatar
The infamous number guy!
My rotor somehow had a few knicks on the surface of it. I'm not too concerned about it though and will be reusing it, i sanded it down with heavy grit sandpaper, hopefully that wasn't a mistake.
Old Aug 18, 2003 | 11:13 PM
expl0d's Avatar
Woo! I wanna buy it! that would look tight as hell under my rx7 posters.
Old Aug 19, 2003 | 12:04 AM
wagondriver69's Avatar
haha i just yanked a motor out of an 85 S.......i was gonna take out the rotors and polish them up and turn em into clocks.....haha they might be good tho is anyones interested
Old Aug 19, 2003 | 11:02 AM
erick1120's Avatar
From the looks of it one of the apex seals blew. I managed to make it home (about 10 miles) this way.
Here's another one of the same rotor. Different spot.
Old Aug 19, 2003 | 12:20 PM
wonder what the housings look like
cause that rotor sure is.....
Old Aug 19, 2003 | 12:48 PM
faye x7's Avatar
brilliantly stupid
haha...you think that is bad? I've got one sitting on my desk that is a hell of alot worse than that one.
Old Aug 19, 2003 | 01:09 PM
The_7's Avatar
Registered Piston Eater
this is kind of a dumb question but...why cant u still use a rotor like that? i mean i know if the housings were scratched it wouldnt seal properly, but what does that kind of damage affect on the rotor faces?
Old Aug 19, 2003 | 01:37 PM
WackyRotary's Avatar
standard combustion
I hate when apex seals go out, they always take the rotor housing with it, unless your using carbon seals. I don't care too much when I broke bridgeports with them, they allways were re-usable!
However with a steel seal, it will not take much to do a lot of damage.
Old Aug 19, 2003 | 02:07 PM
Makwana's Avatar
What about those aftermarket 10mm seals how do they hold up ?
Old Aug 19, 2003 | 03:03 PM
ioTus's Avatar
'84 5-letter
huh, looks a lot like mine!!
Old Aug 19, 2003 | 04:33 PM
RotorMotorDriver's Avatar
Seven Is Coming
Yeah, I cant wait to get into mine to see how bad it is. I can feel large ****** missing from one of the apex seals through the exhaust ports on my rear rotor that lost compression...
~T.J.
Old Aug 19, 2003 | 05:33 PM
standard combustion
I just took me stockport out and apart, found the rear rotor all screwed up too! I hate it! Otherwise, there was no flaking on the rotor housing-now trash, and they are hard to come by in usable condition. If only I took it out sooner and ported it and installed fresh apex seals, the old ones were quite thin on the good rotor. Anyway, I have one good housing out of the engine, and one other good one from another engine, so, a mildport is going back in as soon as I assemble it(thursday or friday). WOOHOO!!! Turbo mildport kicks ***!
Old Aug 19, 2003 | 08:46 PM
The_7's Avatar
Old Aug 20, 2003 | 09:01 AM
Dom's Avatar
Dom
callin' tokyo
I would think you would want three identical surfaces to
have three identical compressions.
Old Aug 20, 2003 | 09:49 AM
The_Dude's Avatar
TT 1st gen ? We'll see !
Pff !! You guys should have seen my rotor when the engine blew ! lol ... 1 apex seal kinda flew out of the rotor I guess, I actually had deep chunks taken out of my chamber lol. Rotor was completely finished, and front ( beleive it or not ) housing completely finished too.
I had 0 compression on the front rotor and about 31 on the rear and I drove that sucker for 1.5 hours to a shop accross town ! Damn thing made it there no problem !!
Old Aug 20, 2003 | 11:23 AM
Bruceman's Avatar
Rotor Power Rules
The 7
damage on the rotor face more than likely means the apex seal grooves are also damaged.
The apex seal grooves need to be in great condition otherwise they will not hold the new seals in place.
4X4CrewDu
Aug 24, 2015 08:44 AM
morataya
Microtech
Aug 17, 2015 01:04 PM
