Tire Width
Old Aug 18, 2003 | 06:59 PM
Driv300mph's Avatar
Tire Width
Ok, now I know that there is a Sticky thread about this, but I couldn't find what I'm looking for...
The stock tires on a '91 rx-7 are 205mm/7in in width... how big can I go without spacers needed? Can I go 8"?
Old Aug 19, 2003 | 02:07 AM
tBoWzeR's Avatar
utters?
you can go as wide as you want...with enough money. but anyways ive read that you can go as wide as 275 safely. dunno if that is with a spacer or not. sorry if not too much help.
-t
Old Aug 19, 2003 | 02:02 PM
Driv300mph's Avatar
well... lets put it this way.. how big of tires can I fit on a 7in rim? -- again, not needing spacers?
I did this mm to inches conversion thing online and it said that 205mm converted to 8.1 inches???
Old Aug 19, 2003 | 02:46 PM
RotorJoe's Avatar
Hooray For Boobies!!!
Are those 16's or 15's. I put 225s on my 2nd gen 15's.
Old Aug 19, 2003 | 09:19 PM
Driv300mph's Avatar
15s... but it shouldn't matter should it? I'm looking to get some 17" by 7" rims, so as long as they are both 7", I guess I could fit 225s on there too... and that'd be enough! Any problems fitting them?
Old Aug 20, 2003 | 03:08 PM
RotorJoe's Avatar
I had no problems fitting or rubbing with 225's on my 15's. True I do have coilovers but the tires were installed prior to the coilovers. I think 225's on the 15's are just about as large as you can go, I could be wrong though. If you are upgrading to 17's or just different rims, the rear will fit like a 285 or something and the front will only fit like a 255 or so. Don't quote me on those numbers though.
Old Aug 20, 2003 | 03:13 PM
RotorJoe's Avatar
oh, just noticed you only what a rim 7 inches wide. You may only be able to get 245s on that, not sure.
rx7jocke
72
Jun 17, 2016 03:48 AM
