Sponsored by: CARiD
Stock air pump removal
Old Aug 18, 2003 | 06:01 PM
I have a stock 93 FD. I am swapping turbos for a pair that have less miles than mine and have been recently rebuilt and I want to pull the air pump off and not replace it. Can this be done or will it screw everything up? Thanks
Old Aug 18, 2003 | 07:49 PM
duboisr's Avatar
The car will idle rich unless you have an ECU that you can lean out at idle . You will need a new belt and you will need to make some block off plates . When you disconnect the wire to the clutch nothing will happen .
Old Aug 18, 2003 | 07:58 PM
Thanks for the input.
12abridgeport
Aug 17, 2015 06:28 PM
