FC wide BODy Need Some WheEl InFO!
Ok well im gonna be running My FC with tein coilovers, and Corksport Wide Front fenders and making my own Wide rear fenders, the same extra width like extra 30mm. I really wanna run like 9's or so in the front and 10's or so in the rear. If you can help please do so.
-Chris
-Chris
Well how much more front spacing will you get in the front? With coilovers and a nine inch wheel your minimum offset should be around a +0 to +5 offset. That will allow a couple degrees of negative camber with the average 9" wide wheel.
Simply based on using a +30 offset 8" wide wheel as a baseline. Push it out another 25mm and you've got your minimum offset required for a 9" wheel.
Rishie
I got a phat deal on my work wheels in similar offsets. email me if you want more advice. I saved well over a thousand dollars by getting the Works over some Kinesis, Fikse, or I-forged custom wheel. rishiegarg@hotmail.com
Rishie
I had JDM PAN SPEED frond fender. I had 25mm H&R spacer. FOR show or street I had 18x10 offset25 BBS LM
Fand B with 265/35/18. for race or track day. I use 17x9 offset 40 with 255. I am try use offset 35 to see what happend this time PLAN to buy ENKEI RPF1 this time
Trending Topics
I "had" a set of Regamaster Evo 17x9 +18 offset that were perfect for running in the front with the corksport front fenders. You could run a lil lower offset like Rishie said but i was concerned with rubbing at full lock and that sorta thing. With 17x9 +18 you have 5" backspacing which is like 1-2" space from the coilovers... plenty of room.
Does anyone have decent pics of the wider corksport or mariah front fenders or the corksport fender lips? I'm going this route ,just want to see how they will look with a stock rear fender...........Thanks JET
