new deck
Old Aug 16, 2003 | 05:41 PM
Forgie's Avatar
new deck
ok I'm putting a new cd player in my 84 gsl-se and I cant figure iut which wire is the ignition lead?
can someone help me out
and I did a search......found nothing
Old Aug 16, 2003 | 09:07 PM
mcinnes's Avatar
NO ROTOR NO MOTOR
umm.. the blue one?????
Old Aug 16, 2003 | 09:41 PM
Maztang84's Avatar
Red should be continuous and the yellow should be ignition.....hope this helps!
Old Aug 17, 2003 | 03:40 AM
ZachstylezRX7's Avatar
The only way to for sure tell is get a tester light and then test em without teh key in teh car and you know that is ur constant and then with teh key on and you know which one is your ignition. A friend of mine thought it was "the red one" but then he found out later that the last owner of teh car got the car broken into and the guy cut off all his wires and so he just put some new ones in and they weren't matched.
Zachstylez
Old Aug 17, 2003 | 04:28 AM
RotorMotorDriver's Avatar
Seven Is Coming
Found this on the forum a long time ago, but I think its right...
LTBlue/Red= 12v+
LtBlue/White= +Accessory
LtBlue/Yellow= -power ant trigger
Red/Black=+ Lumination
White=Factory Amp Turn on
Ground to the body, use the 10mm bolt behind the center console front drivers access panel. Do not use the Red/Black as ground it will damage the interior light circuit and dimmer in the car
Front Speakers (maximum of a 15 watt peak from the radio):
LtGreen/Red= Left
LtGreen/Black= Left
LtGreen= Right
LtGreen/Yellow=Right
Rear Speakers (if applicable, if you have the amplified rear speakers again the Maximum of 15 watts peak is all the stock speaker amp input can handle):
Brown= Left rear
Brown/White= Left Rear
LtBlue= Right Rear
LtBlue/Orange=Right Rear
~T.J.
Old Aug 17, 2003 | 07:30 AM
Forgie's Avatar
yea I figured it out.........thanks
7upra
Mar 25, 2018 11:32 AM
Redrotor
Interior / Exterior / Audio
Dec 18, 2001 05:50 PM
whofarzed
Jun 14, 2001 05:32 PM
